HEDD Announces HEDDphone With AMT Technology
Mar 4, 2023 at 4:51 PM Post #3,976 of 4,489
Hi, I am looking for a used one and found a few in my areas, so I am wondering if there have been revisions since the original model in 2020 (if i am correct) ?
Or if I should only care of the condition ? Thanks for your guidance
I believe the only change is a mod to the headband. Nothing sonic.
Mar 20, 2023 at 10:09 PM Post #3,978 of 4,489
Hey guys, the plastic socket connecting to the headband broke on one side of my HEDDphone. Should I just contact HEDD about a replacement part, or is there another alternative? For now I have it superglued and reinforced with several layers of the same leather tape I used for the mod. Sounded like the superglue broke last night, but the leather is still holding it together.
Mar 20, 2023 at 10:20 PM Post #3,979 of 4,489
Contact for replacement part. They had supply issue during Covid with low quality headband plastic brackets; that was fixed in 2021-ish and newer HEDD models have sturdier brackets.
Loving my HEDDphone lately; I think it out-resolves everything else I have... LCD-X, Focal Clear, HD800S... last to test is the Koss ESP-95X with an 80s era Stax amp (recently tuned up)
ZMF Headband cover is arriving today which should help with the comfort.
I have been using a wool headband from eBay that is for the Focal series headphones; but it fits just perfect over the HEDDphone.
Mar 20, 2023 at 10:30 PM Post #3,980 of 4,489
I would love to get the ZMF band as well, wearing the HEDDphone for more than 30 min already gets my head hurting ☹️
Can u pls post a link where I can buy this ZMF head rest helper?
Thanks in advance!!
Mar 20, 2023 at 11:01 PM Post #3,981 of 4,489
Mar 25, 2023 at 12:32 AM Post #3,984 of 4,489
How long do they take to break in?
Around 50 but up to 100 hours honestly. I've noticed some better bass from 100 to 200+ hours but nothing major.
Mar 25, 2023 at 1:11 AM Post #3,985 of 4,489
I asked Hedd whether the polarity needs to be inverted when attaching Audeze cables due to different pin assignment.
I sent them the pin info for Audeze cables taken from the Audeze website as follows:
"The pin-out for the LCD mini-XLR connectors (those that go into the headphones themselves) on our LCD series cables is as follows:
1 and 4: +
2 and 3: -
Left and right are the same."
Hedd replied as follows:
"Yes in this case you should invert the polarity as our number 3 is positive and number 1 is negative."
Below is the pin assignment diagramme for the Heddphone:
Mar 25, 2023 at 2:24 AM Post #3,987 of 4,489
HEDDPhone needs the ZMF crescent snap to make it bearable for long-term session.
Custom earpads from Vesper will arrive later this year fro me - I dislike the vegan leather material, it gets hot and sweaty on warm evenings - something I am sure is not so much an issue in Germany as it is in Australia.
Mar 31, 2023 at 9:19 PM Post #3,990 of 4,489
What do HEDDphone owners think of the given cable? If an upgrade is recommended, do people have any favorites? I'm thinking of a 4-pin XLR termination, all copper. Thanks for any thoughts. (The HEDDphone is on its way to me).
Stock cable has a resistor in the Y-splitter for whatever reason. It also has inverted phase compared to other mini-xlr cables such as those from Audeze or Meze.
I have used the stock Audeze LCD-X cable with the HEDDPhone; it is not bad but lacks a little bit in technicalities.
I am going to get a nice Ultralinear cable from Custom Cans; it's their thin Litz cables. Nice clean linear sound.
I currently use the Eletech Inferno which is resolving and kicks hard in the sub-bass but is downward tilted. It's a beefy copper cable (and expensive - cost me $400 less than the HEDDphone!)
