headwhacker
- Sep 4, 2013
Go DIY
![](https://www.head-fi.org/attachments/1018872/)
![tongue_smile.gif](http://files.head-fi.org/images/smilies/tongue_smile.gif)
Go DIY![]()
I doubt it. Didn't cost me much except my timeYou will have to buy the amp to get the IC from headstage.![]()
These cables are indeed mass produced, and difficult to source. They'll be available from multiple sources in a few weeks...
Have faith in Robert.. The 4G is still is THE smallest most powerful and user friendly amp for its size. The 5 will be compact and you will wait forever to get one.
Robert remains what he is.
A good guy.
The size is convenient but I would take a custom silver one of the same size over it anyday
I'm a cable believer but at about a 1 inch length I'd bet the farm you wouldn't hear a difference. It's shorter than the adapter you need to use with an i-pod when it's inside most cases!
I am not sure if you believe it or not but I used to re-jack my cable. Just the jack but it makes clearly difference.
No. Just No. Placebo.
