khbaur330162
Vintage Ortho Ninja 🥷
- Aug 5, 2006
A warm headphone with a warm amp? Would this not be overkill? You may think you want a "warm" sound now, but you also may want to get a better handle on what sound signature exactly it is that you really want (before buying all this top of the line equipment). Try the K240 S's (the 55 ohm version) with a PA2V2. Some might question the PA2V2, but it's a really cheap amp and definitely "warm" by most's standards. If not the PA2V2, the Go-Vibe V5. If you're liking what you hear with either setup, I say upgrade to either a Senn HD600 or HD650 (650 being even warmer than the 600) and perhaps a Headfive, Dared MP5 or Little Dot II+.
Good luck.
Good luck.
