shuto77
- Nov 25, 2013
Running my Violectric stack:
- HE-500
- Ether 1.1
- TH900
- T1.1 (Balanced; Late S/N)
- HD800 (Anax Mod)
- DT990/600 (Balanced)
- HE-400
- Sig Pro (ZMF Pads)
HE-500 in a 560 enclosure fixes any/all comfort complaints. Some may find the image a bit small depending on what they're used to. Some may prefer a slightly faster decay/less bloom.
Ether 1.1 is the most comfortable headphone I've ever worn. They sit right in the middle of pretty much every competitor across the board. They isolate a decent amount of outside noise too for an open back design. Some may want more bass and/or more treble. Some may want more warmth.
TH900 is comfortable for the most part. The loose clamp can be annoying. Pleather earpads are my biggest gripe. Some may want more mids, but these are by far the most fun pair of headphones on the market. Wam bam thank you ma'am. Highs may be a bit too prominent for some users who really want to crank the volume knob (to bring mids in line).
T1.1 is very neutral/balanced in my opinion. However, the image itself is very holographic and every FR range sounds distant. These are not an intimate headphone. You're not going to get any intensity out of them. Probably not my recommendation for metal (or rock).
HD800 is bass lite. Most users aren't going to enjoy the separation, imaging, distance, and complete lack of bass. Good for the technical aspect; the opposite of brutal/intense.
DT990/600 has a decent amount of mid bass to be fun with ample treble. The recessed mids and somewhat rolled off deeper bass may steer some users away. They're not the most natural sounding headphone, but for the money I think they're better than a lot of their competitors (that I've heard).
HE-400(not i or s) is fun. Not the hardest to drive, but QA/QC, headband, connectors, gimbels, pads, etc. blow. Comfort kills this headphone.
Sig Pro is a decent offering if you're forced to a closed back. S-Logic isn't for everyone and the stock pads are too small/shallow.
I'm curious myself as to what the Alpha Prime and Ether C 1.1 may bring to the table. ZMF Blackwood/Omni could be another possibility in this range. Oppo PM-1/2/3 all sound like they're too dark and their pads are too small for my ears. I'd audition the DT1770/1990 if given the opportunity as well. May fit the bill depending on the user. LCD-2 is simply too heavy imo; the sound may do it for some, but the treble was far too rolled off and imaging was very "in your head". THX00 sounds like a good offering; I've not gotten to hear one yet. Can't recommend the AQ NightHawk; they're comfortable, but very polarizing and stock cables blow (break). Can't recommend the HD600 either; they suck. Can't recommend AKG anything; uncomfortably big, poor seal, some have crap headbands, and I think there are better options out there.
At the end of the day, a fully open back headphone absolutely crushes a semi-open, semi-closed, and fully closed model. Some may still like how they sound though. I'll end with speakers sound better than all of the headphones I've listened to; assuming the room has been taken into account and EQ'd around it. For most users, headphones will still sound better for less.
How do you like your modded HE 500? The new HIFIMAN enclosure/headband/etc. is a great design.
I loved the HE-400i's signature, and I owned the HE-560, but I didn't have a good enough amp to truly appreciate it.
I know there was a lot of debate whether the newer Hifiman models were superior to the HE-500. Their improved comfort is unquestionable.
