Fearless1
- Sep 29, 2011
Would Gustard H10 be able to drive HE6 properly?
Nope. It will drive them, but no where near what they are capable of. (great amp for the money though)
Based on that statement, you should probably take this opportunity to break the cycle of endless mid-fi side grades, and upgrade to a higher level model. In that case, I'd highly recommend checking out the Enigma Acoustics Dharma D-1000, because it's going to give you everything you are asking for and more.
I quite like the top end of mid-fi. I don't have the money to go for summit-fi grade stuff. I'm very happy with my hd650 and 400i. I'm just looking for something that would be great for my metal tastes specifically.
@Mardrommar and other who listened question about HE6 and forward and agressive mids. I have HE 560 and i dont think mids are forward and agressive and frequency response graph of HE6 looks quite simmilar to HE 560. IMO HD 600 have forward and agressive mids and that is the reason i sold it.
I just love HE 560 i think its perfect i would only like some more bass impact. But maybe im not driving it properly i have gustard H10 on the way so i hope that amp will help.
So my question would be how simmilar are mids of HE6 and 560? Would Gustard H10 be able to drive HE6 properly?
Oh man, you guys talking about the Garage amps got me thinking. I am listening to my Project Starlight (cheap) with stock tube and my sr80e with mod 1 dac. For metal and rock this combo gives my HE400i/Gustard stack a serious run for its money. For a $350 combo this things sounds amazing!!!
IMO midfi is where its at. Sounds incredible and I don't need to get a second job to fund
It's good to know. I will probably buy the Starlight if I don't like the Vali 2 with my Grado 225e.
No gain setting, volume at max is just above 1/4 the pot, and much less I get channel imbalance. Sweet spot for my tastes is 1/4or just shy, so it is not ideal for the grado impedance. I have a project solstice a while back and liked it better, more bass impact and detailed as I recall. Never tried it with grados though. It does have gain settings so I would go for that one instead if you can afford it. I have emailed Jeremy to see if I can do anything about the gain setting on my Starlight. THX00 has the same volume problem. My starlight is setup for hd600, so maybe when you order it he can custom it to your grados.
So since there doesn't seem to be a good alternative to the HE-6 for my tastes I've been looking into it. I probably won't have much more than $1k to spend, so it will be a tight budget.
Levap was nice enough to recommend the ART SLA2 as a decent amp for it. However, I uhh can't figure out how to connect the headphones to the thing. Anyone have ideas? It says it has "binding posts" as outputs.
@Hansotek
thx for the answers man and i will try out your mod.
