ThanatosVI
Thanks, the emotional Support means a lotWell... it's a tough job but I'm sure you'll be able to get through it
I think I'll be going for the Elrog 300b's once it's ran in... provided it arrives!
‘Cattle output’… ‘bile headphone amplifier’…?…?…Is this noname amp included in the list? It seems unusual in that by its description it has both output transofmers and output capacitors and a switch for them.
For example, if you take the Elekit 8900 amp, it is a 3 stage amp with lots of gain. So feeding it even 2V input signal results in way too much gain, when driving headphones from the speaker taps. Meaning, the headphones get way too loud even before hitting 9 o’ clock position on the volume pot. But when driving my Lii speakers (96dB, 8ohm), 2V signal works quite fine, giving me more than enough headroom to adjust the volume. But if I were to feed a 6V signal, I might start losing the headroom to adjust volume even for my speakers.
As for the balanced signal, most single ended triode tube amps use an input transformer to convert the balance input signal to single ended signal.
No, it be nice if it had a dedicated website like the rest of the amps on the list, also a name will be nice lol.Is this noname amp included in the list?
Very nice! Don't forget the Elrogs!So I'll be joining the 300B crowd with an Feliks Envy.
Anyone need an Octave V16 so that I can Fund the Envy faster?
Especially since I'm located in germany they are a must.Very nice! Don't forget the Elrogs!
With the stable of phones you use, I recommend the molybdenum. ACME or 4300E would also be complimentary along with MELZ 1578, VT Sylvania/Ken-Rad and RCA grey glass. As well, don't bother with current production 6SN7.Especially since I'm located in germany they are a must.
Which Version do you recommend?
Thank you, you answered before I eben asked. Just wanted to know which 6SN7s to get.With the stable of phones you use, I recommend the molybdenum. ACME or 4300E would also be complimentary along with MELZ 1578, VT Sylvania/Ken-Rad and RCA grey glass. As well, don't bother with current production 6SN7.
The RCA grey glass are the warmest with quite a bit of bloom where the Sylvania and Ken-Rad are more in the middle (tipped up) with more punch and extension.Thank you, you answered before I eben asked. Just wanted to know which 6SN7s to get.
Can you describe how these 3 variants sound compared to each other?
I concur with one caveat - the Tung Sol VT99/6F8G are excellent as well, with a bit more "slickness" or "wetness" to the sound.The RCA grey glass are the warmest with quite a bit of bloom where the Sylvania and Ken-Rad are more in the middle (tipped up) with more punch and extension.
MELZ is the best 6SN7 I've heard with the tighter punch and smooth top with a more expansive stage.
I use the HA-300 with a 6V DAC without any issues (clipping, extra distortion, etc). Also confirmed to be fine by @Andykong in this post.I assume all of the 300B amps on the list have output transformers or output capacitors (one of them might have both). Of those with transformers, can any of them take a 5,8V balanced input signal (and run properly with it)?
My socket savers arrived today (anode wire was too tight a fit in the recessed socket of the Envy)so I can try the TS and NU 6F8G later tonightI concur with one caveat - the Tung Sol VT99/6F8G are excellent as well, with a bit more "slickness" or "wetness" to the sound.
