Permagrin
- Apr 24, 2009
No problem. I'm really bored and at work so my options are kinda limited.
Just checking out the E7 and E9. The E9 is a desktop amp so I would assume that would be the choice. But it's primarily a dock, it cannot be used as a DAC for a computer. The E7 on the other hand, even though it's a slim device, can be used as a USB DAC (and you can use them together as a DAC/AMP, crazy stuff).
All I can say is keep reading. The more knowledge you gain, the more informed your decision will be. It sucks I know. It's much easier to just buy something because then you'll have it at your doorstep soon. I've bought all of my gear having never listened to it before but spent a lot of time reading these forums and so far I've made out really well (other than my wallet, but whatever).
Also, it's good to make a list and write pros and cons down for each choice you have. Eventually you can cross something off but sometimes you might add another choice...
Cheers!
edit: Oh yeah I looked at the pic of your mixer and there's no way you'd be able to use it with the Mac unfortunately (for sound of course).
Cheers!
