HeadLover
- Jun 16, 2008
I think there is a different, just like with power cords.
Originally Posted by powertoold /img/forum/go_quote.gif I say if you think cables make a difference AND you claim you can hear a difference between 320kbps and FLAC with your system, you should test out the second claim using the ABX Comparator, find out you can't tell a difference even between 192kbps VBR and FLAC, then conclude that all your audio thoughts are invalid |
Originally Posted by Lil' Knight /img/forum/go_quote.gif I think the plug makes difference ... because they're selling cryo-ed plug |
Do you think I made a good decision for the price?
If you like it as a fashion accessory, then it's fine. But I doubt it will have any impact on sound quality at all. The stock cable is all you really need for that.
I'd suggest using whatever is cheapest. Can you use a regular plug instead of XLR?
Nah I will pass thanks,I say if you think cables make a difference AND you claim you can hear a difference between 320kbps and FLAC with your system, you should test out the second claim using the ABX Comparator, find out you can't tell a difference even between 192kbps VBR and FLAC, then conclude that all your audio thoughts are invalid
