money4me247
- Jan 27, 2013
@Thujone, lol why the repeat post
Oooo, removed the felt "star" and the grill dust cover, eh? They probably have AKG air now
After some listening time to the mods I did last night (removed dust cover, star felt,, and switched to pleather pads) I decided to try the he4 without the grill.
The airy-ness has returned along with a better edge to the sound! My guess is the grill was reflecting some sound or was effecting how the driver moved air. If you have any DIY bone to you I swear you will not be disappointed. Beneath the felt and grill are some drivers dying to breath, taking off them off brings a whole new level of clarity to along with that airy sound. At first listen I had to pick up my jaw from the floor. Loaded up some GnR and sure enough... attack and speed is back with that airy sound. Separation also improves substantially with a more natural soundstage. With the grill on (minus star felt and dust fabric) the sound had a hall-like sound to it, without the grill that doesn't happen.
Interesting! Have you tried the grill with the dust cloth after removing the star felt underneath? I wonder if removing both the felt and dust cover causes some reflections off the grill. Man, I'm too scared to not have at least a little bit of protection
You aren't using the velour pads, eh? Interesting.
Is the star felt attached with a spray adhesive ? Ive taken off the grills before, and as with the he400, there's a slight gain to be had. But, I wouldn't want to take that star off unless its easy to re install without glue
