vai-777
- Jul 9, 2004
pick one song, a song you know very well, listen with the pads off then with the pads on, concentrate on the soundstage and the mids, you will put the pads back. I thought that was the cure for the so called VEIL but i realized it did all sorts of funky things to the soundstage and there was definatley some waves bouncing aroundin there, which the foam helps pevent.
If you are going to mod the foam i suggest cutting out a hole right in the cnte but leaing the rest of the foam in. This way you get a little more high end and the damping effect of the foam - its there for a reason.
Originally Posted by Connectz /img/forum/go_quote.gif I love my HD650's too. Now wait until you burn them in and decide to take the "veil" (foam pad) out and listen too them that way. All I can say too that is WOW!!! They open up quite a bit! http://www4.head-fi.org/forums/showthread.php?t=179122 ![]() |
