TheVinylRipper
- Jul 12, 2007
I think it should be possible to put a digital feedback loop around a power amp and control the output according to pretty much any algorithm or filter you want.
Feed the input of your amp with an ADC, read the output with two ADC's one for volts one for amps.
If you know what current you should have at a given voltage and/or frequency you adjust the output with digital feedback around the power amp.
Originally Posted by Daroid /img/forum/go_quote.gif I'm not sure, it would also be nice to have different impedances at varying frequencies too. My take on why it isn't seen is that manufacturers think "the higher dampening factor the better", and thus keeps the output impedance near 0 Ohms - that is certainly the case with speakers amps. |
