I think the consensus is that the Coaxial is the best input path. I extensively tested the 3 inputs and with my battery powered LG V40 using excellent UAPP app the USB was very close the the coaxial. It was better than the optical (but of course those were different sources). My phone was probably a very clean USB output compared to most though so your results may vary. Coaxial is great choice if available.
Happy as a Pig in Schiit: Introducing Modi Multibit
- Thread starter Jason Stoddard
- Tags
- schiit modi multibit
When I had a Modi MB, I used it straight via USB and via coax from an EITR. Actual differences in sound were minor between the two.Just a question, how's the USB implementation of the Modi MB or should i use an other input?
Unless you have a super noisy USB, I'd stick with just USB.
amigastar
- Jan 18, 2011
Yeah, i plan to use USB in fact. Thanks for the tip though.When I had a Modi MB, I used it straight via USB and via coax from an EITR. Actual differences in sound were minor between the two.
amigastar
- Jan 18, 2011
Hey guys, another question is there a Warm-up time on this DAC or can i ignore it. I mean warm-up since the DAC is used it's already Burned-in i suppose.
Runrunsmithfly
Previously known as ssmith3046
I leave mine on 24 hours a day, seven days a week.
+1 for this. R2R DACs need some time after a cold start to reach thermal equilibrium and yields the best results warm. I also leave my multibit Schiit on 24/7.
tim273
Hello everyone!
I purchased a Modi Multibit about a year ago, upgrading from a Modi 3 and I could instantly hear the difference, it was like "WOW"! The things I noticed instantly were the stereo separation and imaging especially in the percussion. I listen to mostly rock, but the left/right imaging and soundstage is amazing and I'm still amazed when I listen to it.
To put it another way, it was the same WOW factor that I got listening to older vinyl records that I purchased on eBay, you know the way music is supposed to sound!
I have it paired with a Bottlehead Crack+Speedball (and some upgrades) and modded Beyerdynamic DT-770 Pros (modded to 600 ohms)
Runrunsmithfly
That was my reaction a few years ago when I went from Modi 3 to Modi multibit. Next was a Bifrost multibit but it sounded the same as the Modi multibit. I thought it would be an upgrade but they really sounded the same to my aging ears. The Bifrost multibit is long gone but I still use the Modi multibit. Best $250 I've spent in audio. Someday a Bifrost 2 but no hurry at all. I leave the Modi multibit on 24/7.Hello everyone!
tim273
Good to hear it's not just me! I leave mine on 24/7 as well.That was my reaction a few years ago when I went from Modi 3 to Modi multibit. Next was a Bifrost multibit but it sounded the same as the Modi multibit. I thought it would be an upgrade but they really sounded the same to my aging ears. The Bifrost multibit is long gone but I still use the Modi multibit. Best $250 I've spent in audio. Someday a Bifrost 2 but no hurry at all. I leave the Modi multibit on 24/7.
amigastar
- Jan 18, 2011
My experience is rather the opposite. I'm not hearing almost any difference to my PC onboard Sound card. Am i doing something wrong?
Edit: Ok so after few comparisons there is certainly a difference from my onboard Sound, the question is how big though. More Smooth, more liquid if i could say so.
But the onboard sound isn't a slouch either thats what irritates me a little bit.
amigastar
- Jan 18, 2011
Just a quick Question, can the Schiit Modi Multibit be used as an USB to Spdif converter?
SolaVirtus
I believe it only has RCA analog output.Just a quick Question, can the Schiit Modi Multibit be used as an USB to Spdif converter?
amigastar
- Jan 18, 2011
Yeah, if you mean by RCA output coax, then yes it has the possibility.I believe it only has RCA analog output.
I want my Concero Dac connect via coax to the Modi MB and from Modi to pc with USB.
muckyfingers
Previously known as 69mustang
All of Schiit’s DACs are Digital In and Analog Out, there is no Digital In to Digital Out.Yeah, if you mean by RCA output coax, then yes it has the possibility.
amigastar
- Jan 18, 2011
Hello,
i have a question. Can i use the Aqvox Power Supply
http://www.aqvox.de/usb-power_en.html
with my Schiit Modi MB? Or do i risk of damaging the Modi MB?
Total: 10 (members: 0, guests: 10)
