gvl2016
- Oct 18, 2016
Thanks gvl:
I'm a bit of a novice. Could you explain when you say, "if your material is up to 16bit/96kHz..."? How does one tell if their source material is at that rate? Also, if it is not, then I won't be able to use the TDA1543 based DACs?
Your music player should usually tell the format. CDs are 16bit/44.1kHz, same same goes for most streaming services such as Spotify with one difference the data is compressed so there's some quality loss to begin with. You could downsample hi-res material to make it DAC-compatible but it defeats the purpose to have hi-res.
