Happy as a Pig in Schiit: Introducing Modi Multibit
post-13413928
Post #3,046 of 4,342
Drrizzt
Hi,
I just bought a second hand modi multibit from a headfier, this is a 110v model and i need some 210v as i live in Europe.
I was wondering if this adapter would be ok ?
http://www.skross.com/en/product/134/country-adapter-world-to-europe-usb.html
It doesn't convert the voltage to 210v, but maybe the ac adapter from the modi is able to switch itself to 210v ?
Thanks folks.
I really look forward to hear that multibit schiit !
post-13413946
Post #3,047 of 4,342
ilcg1
Hi,
Thanks folks.
I think all you need to do is to buy 220v wall wart and that's it. It's like $10 direct from schiit.
post-13413968
Post #3,048 of 4,342
Drrizzt
I see, thanks !
I guess all I need is a wall wart that has the same plug as the modi, as i can buy one at my local store, correct ?
post-13414002
Post #3,049 of 4,342
ilcg1
I see, thanks !
And other things like voltage - you can find it on the wall wart you have. Check with schiit Europe - they should have them in stock.
post-13414013
Post #3,050 of 4,342
Jimmy24
Member of the Trade: TheHeadAmpBuilder
Formerly known as Jimbo24
Dang! Why did the black one have to come out literally a few days after I bought the silver one?
post-13414550
Post #3,051 of 4,342
RickB
Bad Simulation
Bad Simulation
I see, thanks !
The wallwart is AC. Most AC adapters are DC. You really want the right one from Schiit.
Reactions: winders
post-13414638
Post #3,052 of 4,342
Jimster480
Miami
Miami
I finally pulled the trigger on this. The black one was too enticing. Even if I don't like it or don't need it later I know I can sell it easily!
post-13414792
Post #3,053 of 4,342
RiflemanFirst
I think after giving it a try you will like it then decide that you need it!
post-13414793
Post #3,054 of 4,342
psklenar
My Audioengine D1 died.  I decided to take a step up the DAC driving my Audioengine A5+'s ...
Thanks for the positive vibes that pushed me this way folks! :)
pat----
Reactions: volly
post-13415025
Post #3,055 of 4,342
gvl2016
Nah, there are plenty of wall transformers (ac/ac adapters) out there, just pick one with the right connector, voltage and power rating, however if the price ends up about the same I don't see a reason not to buy one from Schiit.
post-13415272
Post #3,056 of 4,342
Jimster480
Miami
Miami
Lol we will see. I plan on using it with my TV in my new house for some powered monitors
post-13415307
Post #3,057 of 4,342
hagenhays
Can anyone on here direct me to a good turntable forum.
I was really pleased with the feedback on dacs..(I went with the mimby and it!)
Now I'm trying to decide between 3-4 tt's with $1k budget.
Thanks
post-13415535
Post #3,059 of 4,342
fritobugger
Hi,
Thanks folks.
The plug adapter you linked will not work.  You either need a step down transformer to convert 210V to 110V or you need to get the appropriate power supply/wall wart from Schiit or one that puts out the exact same power as the Schiit one.
Reactions: Tuneslover
post-13416764
Post #3,060 of 4,342
AviP
pat----
How does it sound with the D5+'s? I'm looking into getting speakers and I'm considering the D5+ with a Modi Multibit. Another option I'm considering is LSR305's connected to Modi Multibit either via a SYS or a dbx goRack. If anyone has any other ideas, I'd be interested in hearing them. Thanks!
