denti
- Apr 17, 2016
Since my amp has no remote, I tend to use the X20 volume. No one has mentioned where they set the base volume. I use +6db, then go from there.
My integrated amp is 0.4v at full power.
so i just bought one of these..
https://world.taobao.com/item/536682540041.htm
off ebay, costed me a extra $100 vs taobao.
i'm guessing that i'll need to do a custom i2s hdmi cable.
i linked taobao because it has a clearer image of the back with the pin out.
can someone recommend a hdmi cable thats easy to modify?
Looks promising. Can;t find it on ebay. Let us know how it works!
I'd still like to try the diyinhk kit, though I don't think I understand how to power it/hook it up. Maybe you can share your experience with it.
just waiting for the kit to get in. i have all the parts i need to get started. At least i think hah.
@ufokillerz it looks similar for sure. On the USB PCIe I2S lines Data=DSD L, BCLK=DSD R, and LRCK=Clock. I know there have been reports that gustard has reversed L & R on the HDMI and some was written in forums about this. Tho I would assume the i2s for PCIe and HDMI would be the same, but you know what happens when assuming. I think connecting inside to PCIe is easier than making a custom HDMI cable. Simon made a custom HDMI cable when he used the audiophonics HDMI I2s board. Good luck.
Hi everyone, how does this DAC compare to the Aune S16?
