Thanks for the share
@zeid2
Do you feel like the Gustard C16 made a significant difference to your system?
Are you currently connecting it to your Gustard U16 and sCLK-EX board?
SC-Cut OCXO’s are better than femtosecond SPXO’s for sure however I didn’t know they were much better than the synthesizers that are on the sCLK-EX. The last time I checked their phase noise measurements they were pretty good. I believe even better than Crystek and Accusilicon.
One thing you should note is that the Gustard C16 outputs a 10MHz square wave. One of SOtM’s preferences is that they like using pure analog sine waves. Having said that, the sCLK-EX might perform better if it was fed that waveform. Certain chips might be optimized to receive a sine wave. Just food for thought.
The sCLK-EX’s synthesizers already performs pretty well. Having a Gustard C16 should help a little more with the phase noise but as previously mentioned, if the cable is too long or not good quality, I wouldn’t be surprised if they both sound the same due to signal loss increasing phase noise. From my experience I have found that Pasternack RG400 is the best coaxial cable for outside clock runs (SMB Male to SMA Female) and RG178 is the best for inside runs to the clock (SMA Male to u.FL [or MCX])
