rb2013
Author of The 6922 Tube Review
- Apr 12, 2013
OK long listening session last night with the DIYinHK DXIO Pro3a. Some more comments - man is this thing small. Smaller then a deck of cards!
Would not work with the Luckit drivers - or the Oppo drivers. Only works with the DIYinHK provided ones. Unfortunately - they are the reduced feature set versions - so now no balance control, or buffer setting changes.
Second - I love the SoX upsampler in Foobar - and usample all my Redbook files to 192K when playing through the APL NWOjr DAC. Unfortunately the XMOS 3.2 version driver did not play well with Jplay 6.2 - running 44k was fine - but on 192k the sound just echoed and dropped out. On 176K the driver crashed and had to be reloaded. Maybe when JPlay upgrades to 6.3 that will be fixed. This is the first time this has happened with any DDC. So I just ran the 3.2 ST ASIO output at 192k - still better then KS - and no issues at all. Jplay can be finicky for sure (and yes I did try many different buffer settings). The Jitterbug worked with the DXIO with absolutely no issues and it's characteristic smoothing helped.
The sound actually improved as the night progressed - so burnin will definitely help.
What really caught me was even greater detail then the amazing Breeze! The level of detail retrieval unprecedented in my audio history. I have heard my favorite audio tracks played on mega systems at big audio dealers - and the stuff I heard uncovered last night was not there. It just goes to show you audio has not fully revealed what the artists had recorded and intended you to hear. And this uncovered detail - just makes listening even more enjoyable. But ultra deep information retrieval and system transparency can uncover faults in the recordings, and downstream system weaknesses. Less refined systems (my amps are class A tube hybrids running the best of the very best HG '75 Reflektors and have been upgraded with a $1,000 of Mundorf TOTL Supreme Silver/Gold/Oil caps) may sound harsh or edgy - or just too bright with the DXIO. The Breeze is much more forgiving.
Lastly, the background noise was supremely black - so the emergence of these very low level details - produced the most holographic imaging I have heard yet. These low level details contain hidden ambient clues that the ear/mind use to recreate the recorded sound field and the 3D point sources embedded in that field. So guitars radiated not only forward, but the key back and side reflections now better revealed, produced a spooky real - in the room effect. Especially on the 5ft tall Magnepan 1.6QR's.
Great stuff!
http://www.diyinhk.com/shop/audio-kits/97-xmos-192khz-high-quality-usb-to-spdif-with-ultralow-noise-1uv-regulator-wmanual-power-switch.html
Great stuff!
XMOS 192kHz high-quality USB to SPDIF with ultralow noise 1.0uV regulator
with high-quality aluminium housing and gold plated RCA connector
This is the best USB to SPDIF for audiophile to enjoy.
Feature:
1) Newest XMOS chip and uses 48MHz oscillator to asynchronous reclock usb audio data to SPDIF line, old XMOS uses only 13Mhz oscillator, over 4x better jitter rejection theoretically.
2) C0G AC coupling capacitor (All SPDIF output equipment requires AC coupling capacitor to avoid the isolated transformer saturated by DC bias component, if no grey color(C0G) capacitor is found in the PCB, that SPDIF equipment can be considered as low end)
3) Ultra low phase noise NDK NZ2520SD oscillator, thin film resistor and Murata isolated transformer (Be care the very common China made Pulse transformer in many 192khz SPDIF equipment is only capable of maximum 7Mbps(i.e. 96khz) according to the official datasheet.) Components are sourced from NDK and digikey directly (guarantee no fake product from China)
4) 1.0uVrms Ultralow noise linear power regulator (use of decade old LM317/1117 regulator is kidding for audiophile)
5) Solid ground plane (a must for high speed digital circuit)
6) No Via in active circuit (via inductance always create jitter problem)
7) Compact size 25mmx 59mm x 63mm
8) PCB can be USB powered or manual switch to external power 5-6V. The external power socket uses the most common plugs size 5.5 mm (0.22 in) in outside diameter. Please notes any modification void item warranty
No drivers needed for MAC OS version 10.6.4 and above
No drivers installation required for Linux with UAC2 compliant kernel
ASIO/KS/WASAPI/Direct Sound drivers for Windows XP to 8 (32 and 64 bit)
Fully featured Thesycon driver package (without 30 min. periodic beeps)
