roman410
- Jan 6, 2013
The DXIO Pro3 can be - in fact must be started with USB power leg connected - even when set for ext power. But the SQ jumps significantly with the stock TeraDak DC-30. Here the LH Labs Lightspeed 2G split cable is invaluable. Just plug the power leg into any free USB port - then start playing - once the signal is detected unplug the power leg. Takes 10 seconds.
One note - I tried to power the Pro3a with the 16,000mAh Li Ion battery from it;s USB port and the DXIO would not work. The Li Ion worked fine on the Hydra Z - in the end I preferred the TeraDak X1/X2. Never got to try the DC-30W as dumb old Audiobyte used a highly unstandard 2.3mm DC input vs the 2.5 that almost everyone else uses - like the DXIO, Wyred Remedy, Uptone Regen, etc...
The total cost to upgrade the 10 el-cheapo 'lytics to totl Nichicon HW's or Pannie FM's was $11. And about an hour of easy to reach (nice double sided case) soldering.
I agree the R-Core transformer is good quality (nice copper shielding touch).
Do you know which discretes they use - thought of trying a couple of Hynes in place.
Another long listening session last night - the DXIO is smoothing out nicely. Sounds amazing. Went through 7 of my favorite Van Morrison albums. Ones I've heard hundreds of times - and they all sounded fresh. New details presented - great fun.
Moon Dance
Avalon Sunset
A Sense of Wonder (the 'space' on this album is a trip)
No Method, No Guru, No Teacher
Enlightenment
Common One
Poetic Champions Compose
I have this DXIO http://www.diyinhk.com/shop/audio-kits/54-xmos-192khz-high-quality-usb-to-spdif-with-ultralow-noise-1uv-regulator-wauto-power-switch.html old version with auto switch to external power and work with 16,000mAh Li Ion battery without problem. I have 2 Li Ion batteries connect together. First is charging from USB charger connect to wall, and first one charge second from take USB power to drive DXIO an my Squeezebox touch. This way I believe have cleaner and not uninterrupted USB power. Also try powered DXIO from Squeezebox touch USB port and cheep 5V wall wart power supply and battery give my best sound. Back in time and compare DXIO with Gustard U12 and DXIO was clear winner.
