FredA
- Dec 15, 2013
Not sure where it is sourced from.
I asked Kingwa about the di-u8 by the way, he does not seem to be convinced it is much better than the di2014 if any. I much prefer the breeze but i have the cheap transfo in the di2014.
I am not sure about this clock mod, i think i have to figure a way to reduce ground noise furthermore. I am thinking about the 6-moons quote above. I think the problem is not noise in itselt but the fact that the zero reference is not perfectly equal between the components. Something like being on shaking floors with not perfectly syncronized shaking if you see what i mean. The ground reference is coming through 2 different path in the dac, especially with i2s. With the isolation transfo of spdif, it should not be such a big problem but then jitter cannot be better than that of the spdif receiver, with is way higher than the breeze's level in my case. Maybe the solution is to use multiple transfos with common reference in the i2s connection, i don't know. I would have to reflect on this. Maybe none of this is relevant, i am not an expert. Just some thoughts.
