thanks Conquerator2,
we can wait for your feedback. ..
Thanks for the advice. I was able to stream a 384 khz 32 bit file just fine from the SOTM SMS-100 through the Gustard. However, quite frankly, I will stop spending a premium on high resolution files. The Gustard make redbook files sounds so fine, I just don't see the need for high resolution DSD or PCM.
Did anybody compares the Gustard vs Berkeley or SOTM converter ?
Well, I can compare it to the Audio-gd DI-V2014 when I receive it, if that'd be any help to anybody
Well, the overwhelmingly positive impressions got the best of me
Besides, if it really is smoother than the USB32 and is a better match with the Sabre, I'll be beyond happy
The DI-V2014 is amazing and I love it, but for all things it does well, revealing all the details there are, I wish it revealed a bit less sometimes, coupled with the uber-revealing Sabre
I think it would be a brilliant match with a Wolfson or Burr-Brown, or any NOS/R2R/tube DAC [or chip]. With some of my tracks, it sounds heavenly in this combo, while with others it is a bit harsh. I'd gladly take a compromise and get great results with all, at a smoother overall tonality.
I'll see whether the U12 will do it, or if it'd only help to a point.
Certainly looking forward to comparing the two units
Thanks, though I wonder how it does with SS Sabre sources, rather than tube DACs.
No offence meant, just not something I can relate to yet [have not tried tubes yet]
I love U12 with the Yulong D18 (ESS9018)
I loved the U10 as well (same combo Chodi was using)
My friends use the original Young DAC with ext power supplies (one on U10, the other on U12) and that's a little better, but 4x the [retail] price.
I'm also very much in the hybrid camp though I don't use tubed sources. I have heard a JAS Musik tube rectified CD player that was astounding to my ear. I'm going to assume that rb2013 is tripping on that same sound.
I just got mine delivered tonight and have it hooked up but only now realized I don't have any computer in the house with an optical drive to get the driver from the disc supplied with the U12 (for Windows). Does anyone have links to downloadable drivers? I know this thread had discussion of alternate drivers as well. Links to those would be appreciated as well. I want to try ASIO.
Thanks!
