- Oct 26, 2008
Mine finally showed up. Got the drivers hooked up and looks like it's all up and running.
Mine DI-V2014 arrived too. It joined the Wyrd to expand my desk's collection of boxes and gizmos
I've been feeding the NFB7 via HDMI through it and everything is fine.
The only difference I've noticed is that it now clocks all signal to 24bit, while the regular NFB7 USB input clocks it at 32bit. No SQ difference though, the DI-V2014 does what it should and it also passes DSP [AC-3/DD5.1], which is something not every device does [the OR5 for example, doesn't].
Zero issues for now, coupled with the NFB7 :}
Perfect!
Now we just need to live in the same side of the planet and we could compare!
The U12 uses a 45MHz and 48MHz crystal, these are readily available at Mouser or Digikey, however they do not stock the femto clocks at these frequencies.
I modded an older unit similar to the U10 using the Crystek CCHD-957 this is a 500fs jitter device, the ones that are advertised as the femto clock upgrades are typically the Crystek CCHD-575 (82fs) or Abracon ABLNO (100fs) .
If you know of a source willing to sell small quantities of these devices at the required frequencies, I would be most interested.
(I have been experimenting with the femtos on the Yulong DA8 DAC, and there are some pictures of them on the DA8 review thread for anyone curious about them)
WOW Ben, Let us know how it turns out. I will be sending you one to mod for me (maybe)
Will do. The modding part will take a little while to get around to, but collecting the parts shouldn't be bad.
As for sending a unit for me to mod, no problem! I take payment in Master 7s...
So, did you guys ever come to a conclusion of what to do about the transformer? Did we find out if it's got the standard wiring or if the primary and secondary are switched/proprietary? It looks like a cool and not too challenging mod, so I'd love to give it a shot if you guys settled it.
Thanks.
I found a local'ish, also taobao.com, spot where I can buy the same Crsytec CCHD-957 clocks that you used, so I'm going to go ahead and buy the Gustard and try the clock upgrade. There's no way the internal clocks are going to be better than those Crsytek ones... I really wish I could find the CCHD-575 units in 45.1584MHz and 49.152MHz like this convertor takes. The 22-25MHz versions are super easy to find, but not these 2 :'-( I would also be really interested in buying some if anyone knew where to get them.
And on page 4 RB2013 also did a filter cap mod, replacing the standard 2200uf Phillips caps with the same rated Panasonic FC ones. I'm gonna give this a shot too, but I'd like to up the capacitance a little as I've had good results doing so on other components. I haven't decided on which caps I'd like to go with or what values, though. I've only ever used Nichicon and Mundorf before. I've heard Elna Silmic II's are good, but would anyone have any application specific ideas for here?
Ah... down the rabbit hole I go again
I posted there this question and received this reply
On the XMOS clocking issue, I believe you described the clock derivation issue as:
“And according to this doc [link], the input clock (say the 24.576MHz clock) is sampled to the internal processor clock. Meaning that the external clock ticks (or transitions) are mapped to the processor clock ticks. This means that the worse “jitter” is when you just miss the external clock transition and must wait for the next internal clock tick. So the worse deviation from the actual frequency is the period of the processor frequency, thus for a 400MHz internal clock part, it is 2.5nS. This is the peak jitter. Thus the RMS number is 2.5/SQR(2)=700 psec””
Was this just a implementation of the XMOS on this particular DIYINHK board using the C7424Z chip, or is it implicit to designing around the XMOS? Sounds that way.
Although it was mentioned by HML that “The Xmos processor data sheets suggest that it may be possible to use the MCLK for the clock source for the BCLK and LRCLK. This is not done in the reference design and not in the DIYINHK board.”
I will post closeups of the Gustard U12 board when I get it.
2014/10/07 at 17:52
BlgGear
Reply
I don’t recall completely, but I think this is inherent in the XMOS chip.
Well I never heard back on the transformer issue - I do believe it's switched and proprietary.
Getting the wiring wrong on that mod would be a horrible sight! Unless you like fireworks
