motberg
i'm all over this.
http://audio-gd.com/Pro/dac/DIU8/DIU8EN.htm
the new DIU8 audio-gd DDC.
This has the multiple digital inputs found in prior Audio-GD DI series..... could be really convenient for some folks.
i'm all over this.
The HDMI output on this one is compatible with the M11 right?
Found them - nothing exceptional - std Chinese OEM TXCO clocks. Elcheapo clock for USB.
I guess the only thing unqie is that Savitech:
I think the new Melodious now has BNC out that the older version didn't have.
So I just did a few mods to my U12 recently. Now the a/c transformer is removed. I believe it was a talema or something like it anyhow. Now it's directly powered by a Teradak DC30W dialed in at 7v. Also just finished installing a dexa newclassd 5v regulator too! I was pleasantly surprised with a nice bump in sq! It's significantly better sounding than stock with a pretty nice build now!
Gustard U12 stock unit (170usd)
Crystek 957 clocks (65usd)
Dip12 sockets for crystals (20usd)
Panasonic 25v 3300uF low esr caps (4dollars)
Dexa NewClassD 5v regulator (10times quieter, 100times better ripple rejection, high bandwidth, ultra low noise) (60usd)
IC swap for Audio-GD HDMI i2s pinout (10usd)
Pure DC Linear power from Teradak DC30W 7v (170usd)
total of appox 500usd... nutz... i know.
powered by Paul Hynes SR3 from usb line (quietest power possible)
so this U12 is totally ideal and sounds quite a bit better than most DDC's out there. But the build cost is a bit high
but if the DIU8 sounds better, i'm selling this setup above for about half what I have into it. So it can help fund the cost.
Audio gd do not believe in clocks. Looks like TCXO to me.
Power supply is shunt regulator transistor based without the usual ULN.
It has been been my contention. Discrete vs ULN reg. Which sounds better.
It's ALIVE!... (from Frankstein)
Nice - the stock transformer although blue is not a Talema but a generic OEM chinese version - so good riddance.
I should note on my ranking that the Empirical Off Ramp 5 With the Dynamo Power upgrade would rank somewhere around 102-104. But it's $2000. I did not own the OR5 but did a pretty exhustive listening comparison with the Breeze on a friend's very high system. Of course that was before the Cerious Graphene power cable arrived. I would bet that the Breeze with the Cerious would be a very tough call. And the comparison I made was with Breeze running SPDIF coax out and a low end Blue jeans cable vs the OR5 using an Empirical i2s cable running i2s into the PS Audio PerfectWave DAC. So we were able to do on the fly comparisons. If I get a chance to repeat that duel - I would bring my AS Statement silver digital RCA cable and the Cerious.
I'm not sure that is the same...could be...but thats another model. it's their analog to digital. notice the two 3.5mm on one side.
I have the Empirical Audio and the I2s is truly outstanding. Mine has the Hynes regulator, but just the wall wart PSU. I was less impressed by the BNC output into my Master 7, but it wasn't tricked out like the I2s one. I've had the parts for DACLadder's HDMI mod on the Gustard for a few months, but haven't got around to it yet. As I prefer the Master 7's BNC input, I might just do the mod to the Gustard and see if it is "good enough" for my limited 192 stuff and get rid of the Off-Ramp. As usual, thank you for your efforts in finding, testing and modding all these devices.
Just got my U12 recently, I've been using it with coaxial output. Man, this thing lowered my noise floor so much. That alone makes it worth the investment. Some of the higher frequencies sound a bit less distorted although that might be placebo, but I'm glad I purchased the U12.
I see - their previous version used the generic OEM JYEC TXCO type clocks with a AudioGd cover print. These look a little different - but they could just be a different OEM order. A close-up photo would be nice.
It looks like a lot of effort on the power filtering and regulation front. R-Core transformer as std now (was an upgrade option before). I agree about discrete shunt regulation vs Ic based ULN LDOs. Just ask John Tucker about that over at Exemplar Audio.
I wonder what had John Tucker commented on the discreet vs ULN LDO ?
