Since my last post above, I picked up a new-in-the-box H16 for a reasonable price. I have many amps already; I bought this one strictly to use as a preamp. It lets me spell the Violectric V281--my favorite SS amp, used 12 hours/day, 7 days/week for 5+ years as a system preamp in my main office system (also my #1 headphone amp). The H16 has worked well as a preamp for ~100 hrs. Not quite as long as I usually burn in electronics, but far enough to try it out as a headphone amp.
This isn't as easy as it sounds. One of the 2 serious flaws of this amp is that the preamp output doesn't mute when you plug in a headphone. That's a terrible omission: turning up the volume on the headphone turns up the volume on speakers & sub. To get around it, I wired another amp/preamp in as preamp, leaving only the input from the DAC plugged into the H16. And for the past 45" I used the Final D8000 planar headphone to compare the H16 to the V281 in balanced mode.
Color me impressed: the H16 is way better as a headphone amp than I could expect. This compact, dense little box sounds a lot like that V281, falling short of V281 excellence in just a few ways:
- The lower frequencies lack the last bit of texture & authority on the H16
- The resolution of faint musical signals deep in the mix isn't quite as good as the V281
- And the overall dynamics of the H16 fall a bit short of the V281 (as does every SS amp I've compared to the V281
Still, this little amp gets pretty close to V281-level sound. The "voicing" of these amps is quite similar. The H16 is a music-first component that won't hurt the listener's ears off with edgy treble transients. I didn't purchase this to use as a headphone amp, so it's a happy suprise that it's an over-achiever when used for that.
Final comment: the H16's other fatal flaw is that its power ratings were gamed on purpose by Gustard. To get the rated power specs, you have to have a balanced DAC outputting 7.0 volts into the H16. That's ridiculous. It's pretty easy to tell with a planar headphone that this amp isn't as powerful as the specs say. Then again, an amp this inexpensive, compact and good sounding (able to give an honest 1.5 to 2.0 wpc in a real world system) is a very good thing IMO.
