I don't recall what the stock sound was but i knew i didn't like way it sounded so it changed it as fast as I could.
I did some more testing some of them was with the same op-amps i used before but this time the Gustard X12 as the dac also as before I wording it the best way i can what it sound like to me. I not that good at wording, I am using the Gustard U12 running I2S to the Gustard X12 into the H10, Prior it was a bifrost uber as the source between the two. I tried op-amps that I did earlier with the gustard X12 and gotten different results so they maybe listed again but with different results then what I had on the bifrost uber. 4x means I using Two pair of single channel op-amps on two Dual to single Adapters.
2x LT1489 + 2x AD797BRZ= Detailed airly Highs Which are Bright,Accurate clear Detailed Mids ,Wide and Big 3Dish Sound stage with Tight Lows
4xLT1357+2xAD797BRZ=Smooth Clean highs,Clear forward mids with impact bass, Tight Lows, narrow Sound stage that is 3Dish
2x1213+2x AD797BRZ=too Bright and boomy,Sharp Highs. Too much Details
2xLT1469+2xAD797BRZ= mids,boomy bass Sharp and airly highs ,Uber amount of Detail
2xLT1361+2xAD797BRZ=Netural, but Volume changes in the highs with ramdom songs which can cause harsh
4xLT1363+AD797BRZ=Highs are smooth and clean but Tinny and too much Brightness, Mids are recess with Vocals hiding, Lows is tight and accurate, Sound stage is narrow
2xLT1489+2xLME49990=Clear and clean Highs tad Detailed,Neutral and Accurate mids, Tight Lows with Neutral Sound
4xLT1122ACN+2xAD797BRZ=Highs Detailed clean but can be bit bright, Mids forward clear, Mid bass Tight, Low bass is deep, SS is good
4x1357+2xLT1122ACN=Highs are tad bright, very detailed, Mids are clean and crips tight mid bass, Tight Low bass that goes deep, good SS
4xLT1357+2xLME49990=Smooth and tad Detailed highs,Neutral accurate Mids but a tad recess,Tight lows with wide airily sound stage.
4xLT1357+2xLT1122=Highs or cleaned but Very Detailed a tad bright and tinny, Tight Mids Clean with accurate bass,Lows are tight, Good SS
2xLT1057+2xLT1122=Mids clear n tight,Lows Deep and tight,Small SS
2xLT1057+2xAD797BRZ=Highs is smoothed while still clean, Mids are tad forward with tight bass with good Vocal, Lows are impact and a bit boomy and Distorted. Sound Stage is a good but the bass is in your face
2xLT1469 +2xLT1357=Highs clear Very Detailed , Mids was clean and a tad forward with mid bass impact, Lows are Tight and accurate, Sound Stage is good
2xLT1355+AD797BRZ=Smooth Detailed Highs,Neutral Mids with Tad bass impact,Tight Lows 3Dish medium Sound stage
2xLT1489+2xLT1357=Clean and clear highs that are airily, Clean mids with great voical, Tight Lows with a wide and big sound stage
2xLT1469+2xLME49990=Highs was too bright
4xLT1122+2xLME49990=Airly Detailed Highs that are a tad bright,Mids are a tad forward and clear, Lows are Tight Sound stage is huge
2xLT1057+2xLME49990=Smooth clean highs, Mids Neutral, Tad Boomy lows. Small Sound Stage not good depth 2D'sh
2xLT1355+2xLT1122=Smooth Clean Airly Highs, Mids are a tad Forward with Medium Bass impact and Very Good Vocal,Tight Lows with Big Sound Stage
2xLT1355+2xLME49990=Smooth Clean Highs, Mids are neutral with slight bass impact, Tight Lows with Neutral sound stage
2xLT1489+2xLT1122=Smooth Airly Highs with Good Details,Clean Mids with Great Vocial and Controlled impact-ful bass, Tight Lows with 3Dish Sound Stage and Wide
