phcassa
- Dec 12, 2010
I'm very curious about this amp, specially after the opnion ofe an experienced member of this community.
Gustard H10 is presented as follow:
GUSTARD H10 High-current Discrete Class A output Stage Headphone Amplifier
Features:
1.H10 is a high-current discrete Class A output stage headphone amplifiers, each channel consists of two independent amplification circuit, has RCA inputs, balanced input, you can easily connect a variety of sources.
2 machine using a buffer amplifier plus pre-amplification stage main components. Buffer preamp gain adjustment function with four segments, with the four pairs of audio power output circuit tubes on the CPI, you can easily drive a variety of different impedance headphones.
3 using two 25W seal ring cattle, independent power between left and right channels, effectively reducing the left and right channel crosstalk.
4.AC115V/230V international voltage input.
5 Adjust the volume potentiometer placed at the back of the input stage, effectively shortening the audio channel path, reducing interference.
6 start-up delay, DC offset, overload, protection circuitry to ensure the safe use of the machine.
7 aluminum chassis, before grinding Shahoulasi processes, machines all black.
8.RCA single-ended and balanced XLR inputs, input switching and gain adjustment.
9 tri-band balanced sound correctly, the output resistance low current, suitable for most headphone mix.
10. Rigorous design, reasonable layout, elegant lines, solid materials.
Technical Specifications:
Signal Input: 2x XLR female, balance
2x RCA, unbalanced
Maximum input level: +21 dBu, impedance 10kΩ
Input impedance: XLR: 10kΩ, RCA: 68kΩ
Input Sensitivity: +6 dBu
Main amplifier gain: +8 dB
Main amplifier gain adjustment range: -4 / +2 / +8 / +14 / +20 dB
Frequency response: 0-55kHz (-0.5dB)
Damping Factor:> 400 @ 50Ω
Dynamic range:> 128dB (A-weighted)
Background noise: <-100dBu (A-weighted)
THD + N (1kHz 1W @ 100Ω): <0.00035%
THD + N (1kHz 0.5W @ 32Ω): <0.0007%
Crosstalk:-110db (1kHz)
Headphone Output: 1x 6.35mm TRS Jack
output power
ifferent impedance has different output power
Output power: 570 mW (600 ohm load); 2200 mW (100 ohms); 2700 mW (50 ohms); 2000 mW (32 ohms); 1000 mW (16 ohms)
Power supply voltage: 230V AC/115 AC; 50/60Hz
Power consumption: ≤ 20VA
Machine Standard: GB a three-prong power cord
Machine size (not included prominent part): length × width × height = 273mm × 190mm × 70mm
Package dimensions: length × width × height = 385 × 280 × 150mm
Weight: Net Weight 3.3KG, including packaging 4KG
Look really nice to me. However, wold this be an amplifier clone of Violectric V200 or just something that has used V200 as a start pointing?I find then visually very similar.
V200 view by inside:
I really would like to know opinions about this amp.
My english is not very good, so sorry.
It absolutely does. Gain switches are on the back (-12, -6, +6, +12).. so it's got the versatility to drive everything from my highly sensitive cIEM (UERM) to the 560 with ease. Here's the eBay page from where I purchased it. I had an extremely smooth transaction and the seller was excellent to deal with. I've had the amp for a couple of weeks and couldn't be happier with it. In my time in this hobby, I've owned and listened to enough SS amps to get a good idea of the landscape.. and this amp is better than anything I've heard at the price point..and one of the best ss amps I've heard under $1000. It's the last solid state amp I anticipate buying for the foreseeable future, actually... I'm that satisfied with it.
Features:
2x RCA, unbalanced
output power
