SpursForEver
Maybe a defective capacitor...do you control the volume using the R26 ? Does the rustling vary with the volume ?
could try the RCA output to see if the rustling is still thereMaybe a defective capacitor...
Hlasitosť na DAC nepoužívam, je nastavená na FIXED.ovládate hlasitosť pomocou R26? Líši sa šušťanie s hlasitosťou?
Sorry, but I accidentally copied my language in the translator.You might have a capacitor problem on the chain. Had this problem on my HP Amp.
REMINDER: This is an ENGLISH ONLY forum (for easy communication). Use a translator first before posting.
I tried it and it's the same, almost completely silent from the left speaker. It plays a little, but compared to the real one, it's 20 vs. 80%Caps are all over...Like the suggestion of the previous poster. Change to RCA/SE output if it helps.
I already wrote that I have Gustard R26 24 days after the warranty, so it is more than 2 years old. Do you think it is worth sending the DAC for repair directly to the Gustard company? I have about 10,000 miles on it.I guess time to claim warranty/repair if available. Contact Gustard support and your dealer where you bought it.
have you tried different inputs ?I already wrote that I have Gustard R26 24 days after the warranty, so it is more than 2 years old. Do you think it is worth sending the DAC for repair directly to the Gustard company? I have about 10,000 miles on it.
Yes of course, usb and I2S
