Hi. For about a month now, I've been experiencing a small but very annoying problem, and I'm wondering where it's coming from. Maybe you can help me with this? Specifically, at random moments, I have half-second interruptions in audio playback from the LAN connection (the optical connection works flawlessly). What have I done?
1. Flashed the router, set everything up from scratch."
2. Replaced the LAN cable, changed the port on the router.
3. Flashed R26 1.43 (the same as I had before).
4. Pinged R26 to check for transmission errors. No errors found.
The problem still persists. It can be fine for an hour, then several interruptions occur in one track. How do I play music? BubbleUPnP, Tidal, mconnect - all apps on Android. The only thing I've noticed is that when selecting the source in mconnect, the Gustard icon occasionally blinks. Please let me know if any of you have encountered such a problem and if the icon blinks in the mconnect app - see attached files. First is extremly short, second is 2 sec long, after that all repeat.
