GUSTARD DAC-R26 Balanced Decoder R2R+1Bit Dual Native Decoding Music Bridge
Sep 27, 2024 at 6:49 AM Post #9,271 of 9,914
Just another question. Can the both the outputs of the Leo clocked be used? I saw most of you disabling one output. I am thinking if i would be adding a streamer in the near future that can also benefit from an external clock.
It is difficult to sell stuff here.
Sep 27, 2024 at 7:19 AM Post #9,272 of 9,914
Hey, i have read somewhere that if you want to use both outputs of the Leo Bodnar GPS clock, then output 1 and output 2 must be configured differently. As a guide i'm using this picture (except that i'm using Output 2 instead of 1).
Is there someone who has using both outputs from the clock? In my current system there is R26 + U18 and maybe someone knows if there be an upgrade if using both clock's outputs - one to connect U18 and one to connect R26? Also, can you share your opinions what configuration of settings/inputs/outputs sounds best to you?
Sep 27, 2024 at 8:55 AM Post #9,273 of 9,914
This is the one those of us here have used very successfuly:
Precision GPS Reference Clock​
I just saw a YouTube review where the reviewer found little improvement using fiber converted LAN, but a clear improvement using a relatively cheap no-name 10MHz clock, which got me thinking about trying out a clock like the one you refer to.
What sonic benefits am I supposed to hear with a possibly better clock?
Better resolution in general, better treble quality, both, or something else?
Sep 27, 2024 at 9:02 AM Post #9,274 of 9,914
All you have writen is true but to me there is another huge benefit from using an external clock - the soundstage. There is more life in it after connecting a clock, is like the clock added some additional layer to the soundstage's depth and now all seems more natural, more from 2D "Wall of sound" to a more real 3D picture.
Sep 27, 2024 at 9:45 AM Post #9,275 of 9,914
I just found an interesting comment regarding femto vs pico clocks:
"... the old clock had random low frequency jitter. The other does not. This has nothing to do with whether the clock is accurate to femto or picoseconds."
So, what Amir at ASR seems to say is that a "picosecond clock" or a "femtosecond clock" doesn't say whether one is audibly better than the other.
Sep 27, 2024 at 9:50 AM Post #9,276 of 9,914
All you have writen is true but to me there is another huge benefit from using an external clock - the soundstage. There is more life in it after connecting a clock, is like the clock added some additional layer to the soundstage's depth and now all seems more natural, more from 2D "Wall of sound" to more real 3D picture.
I had this moment of 2D to 3D when i changed my final interconnect to the one made by my custom builder, from the ali express nordost gold 2. Hopefully the clock will improve it further. I am still thinking should i get the lhy ock2s....since jake also has it..😅
The newer version
Just found this amazing item on AliExpress. Check it out!
SG$1,229.72 | LHY AUDIO OCK-2S fever audio 10MHz SC cut OCXO high-precision ultra-low phase noise constant temperature clock crystal oscillato
https://a.aliexpress.com/_okjWoD3
Sep 27, 2024 at 10:07 AM Post #9,277 of 9,914
I have started using ebay clone Nordost Silver plated/ air insulated wire strands from Valhalla speaker cable for interconnects.
Sep 27, 2024 at 10:10 AM Post #9,278 of 9,914
How do you find the cables? I find the nordost gold not too bad. A bit sibilant on the highs and less 3D on the soundstage when compare to the one made by my local custom builder.
Custom cables
Sep 27, 2024 at 11:02 AM Post #9,280 of 9,914
What are those RCA plugs? I don’t recognize them.
I am not sure either. I was told that it was silver. My custom builder did asked if I prefer gold, silver or rhodium. Thats the only clue i have in the below picture.
Sep 27, 2024 at 12:05 PM Post #9,281 of 9,914
I have some highend Cardas RCA connectors where the outermost part actually screws on from the front after all of the soldering is done that look similar. I have most recentlt started using ebay low mass (plastic) RCA connectors.
https://www.ebay.com/itm/285541540406?var=587498903834
But all of my equipment is XLR now which have inherently low mass contacts so I just use the Neutrik connectors with strands of this wire. Since I am DIY I can make them as short as possible at 0.3 meters for my desk top stack.
https://www.ebay.com/itm/1253375306...9EWMP8&hash=item1d2eb2f105:g:fK8AAOSwDo5kCtvX
Sep 27, 2024 at 12:07 PM Post #9,282 of 9,914
Ok. Placed order for Leo Bodnar clock. 😁
Sep 27, 2024 at 12:42 PM Post #9,283 of 9,914
Sep 27, 2024 at 4:18 PM Post #9,284 of 9,914
` You can use both outputs and set each to a different setting if you wish
Sep 27, 2024 at 5:10 PM Post #9,285 of 9,914
The newer version
What is the OCK-2S? HAven't seen that anywhere except your aliexpress link. Even the manufacturer website doesn't list a OCK-2S?
I have the LHY OCK-2 and am very happy with it, just wondering if this is a real product or not?
