GUSTARD DAC-R26 Balanced Decoder R2R+1Bit Dual Native Decoding Music Bridge
Sep 25, 2024 at 10:55 AM Post #9,256 of 9,922
Either adjust the treble in your system or listen only at nigth. As SusayTofu said, sometimes we are not in the mood.
Yes i stopped listening, maybe its listener fatigue🤔. It is night time here btw. 😁
Sep 25, 2024 at 10:57 AM Post #9,257 of 9,922
I did try to plug my preamp into the filtered socket of the power conditioner. The brightness is gone but it also takes away the dynamics.
I think i remembered that if the interconnects were to run in parallel with the power cables the sound will be affected. Will try to check on this too.
I have stopped listening to take a break. Will try again tomorrow and if it sounds good. It could probably be me. 😅
It was smth downstream. Cables should always cross each other not run parallel, but probably not much effect. Get a scope.
Sep 25, 2024 at 10:57 AM Post #9,258 of 9,922
Sep 25, 2024 at 12:04 PM Post #9,259 of 9,922
I think the key here lays in the “sustained longer bass notes”. R26 bass sounds a lot like music coming from LPs and Sabre bass has no extension (at least to my ears) I have also noticed that after 30 mins of playing music using R26, bass becomes a bit tighter.
The bold part makes me sure my initial point was and is right. Of the two DAPs I have, one has a Sabre DAC chip, and that is the DAP with most sub bass extension (HM901s). My point is that the DAC chip or R2R ladder is only a part of what makes a DAC sound like is does. The (analog) output stage plays a big role too, including the sub bass extension. A part of that is the output impedance in relation to the input impedance on the pre-amp.
Sep 25, 2024 at 12:51 PM Post #9,260 of 9,922
Sorry for the noob question but what does
This thing do ?
I you have an FMC mod, replacing the Fiber SFP modules to this $38 wonder will uplift your system SQ.
Sep 26, 2024 at 8:36 AM Post #9,262 of 9,922
@BShaw at AS they attest its better than Melco"s $1K countrerpart. Alex of Uptone Audio higly recommends it.
Have the Amphenol in order. BUT my $10 a pair 10GTek DAC Cable throunces my $86 a piece Finisars. So...
Its a $38 a pair investment. BUT if those guyz says so...So trying won't hurt a bit...
Longest is 7 meters:
https://www.mouser.com/c/?m=Amphenol&q=SF-SFPP2EPASS
Sep 26, 2024 at 8:45 AM Post #9,263 of 9,922
I’ve had the Finisairs as well for about 2 years. I’ll try the Gteks they’re $45 for the 10m length, worth a shot, thank you.
Sep 26, 2024 at 9:29 PM Post #9,264 of 9,922
Hey Mickey, would you mind dropping a link to the AS thread where they're talking about this cable?
Sep 27, 2024 at 1:53 AM Post #9,265 of 9,922
@BShaw Sure!
DAC Cable Thread in AS: LINK
Explanation why DAC cable is superior: LINK
In HF from this post onwards (esp. on the last page): LINK
NOTE:
  • There are two types of DAC cables (Passive and Active|). The correct type is PASSIVE (see explanation on link #2).
  • Some DAC cables has EEPROMS for dedicated brands (HP, Dell, Cisco, Lenovo etc.). Be sure its the SFF-8431 open standard.
  • Amphenol DAC Cable has two types of wires, be sure to get the: quad shielded SKEWCLEAR version.
Anyway, the right cables i already posted on the Mouser links HERE (last part of post). So don't worry yourself too much on the above notes.
I am learning also as i prooceed. So sorry if i keep updating my posts.
Sep 27, 2024 at 5:17 AM Post #9,266 of 9,922
Sep 27, 2024 at 5:27 AM Post #9,267 of 9,922
Ask @Jake2 he has one..
If I'm not mistaken, this is the one: LINK
Sep 27, 2024 at 5:43 AM Post #9,268 of 9,922
I just ordered the Harmonic Tech 50 ohm cable without a clock 😅
Sep 27, 2024 at 6:43 AM Post #9,269 of 9,922
This is the one those of us here have used very successfuly:
Precision GPS Reference Clock​
Sep 27, 2024 at 6:45 AM Post #9,270 of 9,922
This is the one those of us here have used very successfuly: (sorry for such a huge picture)
Thanks Fluty
