GUSTARD DAC-R26 Balanced Decoder R2R+1Bit Dual Native Decoding Music Bridge
Jul 30, 2023 at 4:12 PM Post #6,992 of 9,965
Which screws are these? Only the outer ones, just enable the lower ones? Is it necessary to dismantle the cover as well? It's worth a try
Start with the bottom screws. Look if they are to tight fastened. If you struggle to unfasten the bottom screws, then they are to tight.
When you tighten back the screws, then give them only a faint tight.
Not every device is affected by to tight screws, so the outcome on this tweak can vary from device to device.
Jul 30, 2023 at 4:30 PM Post #6,993 of 9,965
Hello,
I'm helping a little.
Turn the Gustard over onto a soft surface or use a support.
The arrows marked in green show which screws you loosen in the picture.
You will see double screws on the left and right, one at the top and one at the bottom, in the middle and further down.
The bottom of the double screw loosens the bonnet.
Drehen Sie den r26 um und lösen diese Schraube in Bild zwei.
Und können dann die Haube lösen,ohne das etwas passiert.
Back to picture 1:
The arrows marked in red are the screws from the circuit board.
Loosen them first, that's all.
Continue in picture 1, loosen the 4 screws completely and put them to the side.(yellow arrows)
And carefully take down the R2R conductor by lifting it only in the middle and then opposite. The R2R conductor is clipped.
If you do not dare to do this, leave it alone.
After removing the conductor, there are 2 screws to be loosened.
The next step is to loosen the screws at the connections.
I left the 10 mhz and Bluethooth connections in place and loosened everything else.
When you have loosened everything, first tighten the screws on the circuit board.
(Red arrows and the R2r wire back on and tighten the screws crosswise slightly).
Here I tightened the screws until they were tighter and then turned them back a 1/8 to 1/4 turn.
Once you have done this, do the same for the connections.
This has the following effect:
You take all the voltage out of the board without putting pressure on the connections.
Finally, put the cover back on.
You can also loosen the very large Allen screw on the back and tighten it slightly again. These are the screws for both transformers.
That´s all.Hope it helps.
Jul 30, 2023 at 4:33 PM Post #6,994 of 9,965
I will try and let you know how I believe in voodoo in hifi. I was pleasantly surprised more than once.
Jul 30, 2023 at 4:45 PM Post #6,995 of 9,965
Did not believe in Voodoo either, but this tweak took me by surprise.
In the end it is not Voodoo, it is physics.
Stiff object transfer vibrations better than loose objects (in this case chassis).
As @Deleeh stated, his device was not affected by to tight screws, so the outcome can vary from device to device.
Jul 30, 2023 at 4:47 PM Post #6,996 of 9,965
Hello,
Back to picture 1:
Have noticed any improvements by loosening the PCB boards?
Jul 30, 2023 at 5:10 PM Post #6,998 of 9,965
Hello,
Back to picture 1:
thanks for sharing, could i ask will the sound be more full or more airy doing this mod, especially in the mid range and vocals
Jul 30, 2023 at 5:25 PM Post #7,000 of 9,965
Hello,
Back to picture 1:
Thanks, @Deleeh , for the detailed instructions.
@m-i-c-k-e-y , IMO, it might be useful to add this post to the first page of the thread.
Jul 30, 2023 at 5:35 PM Post #7,002 of 9,965
Hello,
Back to picture 1:
What you described above in your post, have you done this to your DAC?
What was the outcome?
