Yes that's one option to earth/ground the shield. I was initially planning to be lazy and just use copious quantities of copper tape with conductive adhesive to the aluminium chassis incl the power supply section divider board as the means of grounding the shield. But agree a lead to the IEC earthing point on the chassis is desirable. I think the shorting risk we were contemplating though was more if two conductive points on say the edge of a circuit board made contact with the bare edge of a copper shield... it wouldn't be great, chassis / IEC AC grounding point or not.Why not just solder a lead from the shield to the ground pin of the IEC?
This is some of the copper sheet I'd ordered... well, thought I'd ordered.. it's still in my cart dammit.
https://www.aliexpress.com/item/1005003966949048.html
https://www.aliexpress.com/item/1005003201762844.html
Normal copper foil tape is around 0.05mm thickness IIRC, which is very thin, fragile and will drape/droop if adhesion fails. So I was thinking something of getting some copper sheet about four to ten times the thickness for greater rigidity, less flex but still the ability to fairly easily cut and precisely form it to fit a confined space with tight tolerances (especially the gap between the R2R ladder and analogue boards/sections which is v tight) i.e. 0.2mm- 0.8mm thickness. Had intended to order a range of thicknesses and dimensions as below to see what worked best. Need to pull the trigger.
