I have pretty much the exact same setup.
Mac M1 mini (Roon + HQplayer) > Zen Stream > U18 > R26, with the OCK-1 clocking both (c2 cable to U18 and generic 50 ohm to R26). DSD256 & PCM384. Have had my LHY for 3+ weeks now, so a little longer running in.
Have also tried Mac M1 HQP > R26 internal NAA streamer via ethernet. PCM768 & DSD256. Haven’t managed to get DSD512 working yet on the M1.
R26, U18 & OCK-1
Agree with you with the nature of the OCK-1 improvements which are perhaps a little more pronounced for me:
- Probably the biggest benefits are with the Zen/U18 chain, by connecting the clock to both the U18 and DAC, brings additive benefits, uplift of U18 ext vs internal is say 1.5x that of switching the R26 to ext clock
- there’s a more subtle but still valuable effect with the R26 NAA direct, an increase in depth and sense of acoustic space, note decay with the R26. R26 alone sounds a touch flat in AB comparison. EDIT: It’s not subtle when you use the Gustard C2 to connect the OCK-1. I just AB’d the generic 50ohm BNC vs the C2 connected to the R26. DAMN. I’d say the OCK1 + C2 is at least twice the improvement in sound over the R26 with internal clock than the OCK1 + generic BNC. With the C2 the soundstage is both higher and deeper with better macro and micro dynamics. Not subtle. The C2 let’s the OCK1 show what it’s capable of.
R26 internal streamer vs Zen + U18
I have to say the R26 via its internal NAA with PCM768 is to my ears a big step over PCM384 on either setup, the latter the max the Zen is capable of of course. R26 is very, very impressive for a ‘one box’ DAC/streamer solution when fed PCM768 from HQplayer. A really engaging dynamic, detailed (if not quite DSD level), full and natural sound with heaps of PRAT. The OCK-1 adds the finishing touches.
On DSD256 I’m still comparing the two (see caveats below), but listening last night it was very close, in fact I think I’d give the edge to the R26 NAA direct, vocals a touch more focussed and palpable, if not PCM768 level. I like the greater precision of the DSD256 soundstage vs PCM, and the greater definition of bass notes but miss the dynamic energy and tonal weight of PCM768. A mix of the two would be awesome… maybe DSD512.. wish me luck.
CAVEATS / posssible limiting factors
- my Sopra no 1’s are pretty resolving so YMMV
- Using
this USD100 Aliexpress USB cable from Zen (supposedly Ok, but need to try another)
- generic Cat 5/6 Ethernet cables (next on upgrade list)
- Power - all generic power cords etc apart from Ifi Power X for Zen (looking at regen + cords)
- I need to take the Zen out of the chain and try PCM768 & DSD512 via the U18
I need to try swapping the clock cables around
