winged creature
- Mar 15, 2005
Any news when firmware update will include tidal connect?
I did say that this was a very big topic but OkThats a misleading way to look at the LSB processing accuracy for a R2R DAC.
Look at linearity if you want to understand the ladder processing ability.
Another review
Great advice BShaw, thanks for the advice and the link!Hey Rock -- 200mb is more than enough to stream hi rez.
If you're going the FMC route, you've probab;y already read up here enough to make you dizzy, and I'd also refer you to the sticky on the first post of this thread. FWIW, for me the Finisair ( https://www.ebay.com/itm/125418199525 ) at $24 for 10 meters was a no brainer and a definite step up from the previous multimode fiber I had before it. As for linear power supplies, if you want to go cheap, get a Jameco Reliapro for $25 for the DAC end and call it done. I bought a LHY and moved the Jameco to the dirty side. I'm still trying to get my CD collection to sound as magical as my streamer set up. Speaking of streaming, check out JPlay, it's a UPnP app that blows bubble out of the water. I use it with Qobuz, not 100% sure if it does Tidal, but very soon there will be an update to the R26 which will include Tidal Connect; they've been earnestly working on it for a few months at least.
Sorry if that's TMI. just had a few minutes and thought I'd barf a few things out.
Another review
Just the advice I was looking for. I can now comfortably look for a "used" R26 without worry for buyer's remorse regarding DAC performance. Thx!Great review and super informative. In my humble opinion the R26 is the best "bang for the buck," on the market. I have tried Top tier Denafrips, Holo Audio and many $3k D/S DAC's in my system and while yes, when you get over $5k for a DAC there is superior audio differences from the sub $3k DAC's but the difference is so small with the R26 the I would rather spend the $1650(USD) on the R26 and invest the other monies in a high quality headphone amp, which I did with the Ferrum OOR / Hypsos. Simply, the R26 is not better than the Holo May / Spring, Denafrips Terminator but it is a VERY close second at a fraction of the cost.
I also have an older Netgear moden/router combo unit and my download speed is presently 200 Mbps, but some here speak of a minimum speed of 500 Mbps where I have read elsewhere that you only need speeds of 20 Mbps to listen to lossless music on-line.
Thanks! I just purchased some cat6 cables to go from my mesh unit, but I realize I didn't need the speed necessarily. I also chose the color I wanted, ha.Audio File Size Calculator
Even if you play a 5.1 channel 32bit PCM768 audio you're still below the 20MB/s mark.
Thats incorrect. You need to be a bit careful making a habit of coming out with definitive statements that are just wrong and can mislead beginners.I don’t think any R2R Dac is capable of 16bit output resolution.
It was correct. You need to be more careful [...], especially when trying to correct others.Thats incorrect. You need to be a bit careful making a habit of coming out with definitive statements that are just wrong and can mislead beginners.
For anyone wanting to look into this check out the data. Linearity plots and 16bit to 24bit FFTs show the resolving power of a R2R.
