migo
Yes, will need to apply 1v3 update if you will not like 1v4. Update always rewrites whole SD card (used part/partition of it to be exact).Is there a way to revert to 1.3 if 1.4 screws something up?
Thank you CobrabucketAirplay works for me with Roon and a Win10 PC.
oddly after being plugged in for a while i see this connnection? Is that what I am looking for ?I again tried the method using Balena Etcher and still no luck. Both image updaters just cannot see the firmware drive
What is the downside to not being able to update the flash drive firmware? Will I eventually not be able to use this DAC as the connections will not work? USB? Already Roon won't connect. Other ports?
Do I need to return this unit or will it function with the old firmware for a long time?
Any insights would be very helpful...
Thank you !!
Done, no issues so far. Had to change the usbc cable as the one I initially tried wouldn’t see the drive…Yes, will need to apply 1v3 update if you will not like 1v4. Update always rewrites whole SD card (used part/partition of it to be exact).
Just try a bunch of different cables until it works…
Being new here, I am unable to help you myself unfortunately.
I will try the USB C cable for a fourth time Worth a shot again I guess.Done, no issues so far. Had to change the usbc cable as the one I initially tried wouldn’t see the drive…
I've tired two cables, second worked for me...I will try the USB C cable for a fourth time Worth a shot again I guess.
For some reason there is no upsample option over upnp in audivarna for me. And there seems to be some weird reverb on voices and instruments compared to roon. Any idea why?In my system, Roon and Audirvana sound the same in Bit-Perfect mode.
While upsampling, Audirvana sounds a bit better, but Roon sounds good as well.
yesYou are sure you have SWITCH OFF the unit AT THE BACK?
