GUSTARD DAC-R26 Balanced Decoder R2R+1Bit Dual Native Decoding Music Bridge
Dec 2, 2022 at 2:37 PM Post #2,191 of 9,916
The main focus of good audio quality, is being able to hear it from a fair objective perception. Placebo may interfere, and thats ok and fine. If I tell you guys that I hear the improvement, it does not matter what everybody else thinks. However I also think that its totally fine to be critical against the opinion. As long as we keep it to the main intention, enjoying good music, breaking the limits of the sound in the setup/chain.
Cheers!
I haven’t been in this hobby for very long however I have been to audio shows here in North America Poland and Germany. I have met a lot of interesting people and have cultivated friendships with like minded individuals. For the most part everyone that I have met are joyful never negative lashing out at others because of something they said . I suppose there is a small fringe group of people that get triggered easily over small matters however for the most part all around this hobby is fun at times thought provoking and from time to time little surprises .
Dec 2, 2022 at 3:16 PM Post #2,192 of 9,916
Correct buy that kit and a cable and you are good to go.
Each of those FBMs is 5v/1a
Here is the Linear power supply I use.
Runs them both
25VA DC 5V Bench Linear Power Supply Audiophile,Desktop Power Adapter Regulate 5 Volt 3A 4A for Raspberry pi 3 Model A+ B B+ Plus Micro USB https://a.co/d/dG199Il
Alright. You guys talked me into it... Got that kit from flea bay and the cable you linked. I have a single connection 5v lps and another 5v ifi smps. Excited!
Dec 2, 2022 at 3:38 PM Post #2,194 of 9,916
1. It’s a fiber optic cable.
2. It’s all still in the digital domain. It’s not in the analogue domain until it hits the dac.
3. Jitter is the variation in time delay between when a signal is transmitted and when it's received over a network connection.
It’s amazing how opinionated and uneducated you are. Here read up.
https://www.atatus.com/blog/jitter-vs-latency/
Maybe you should pay more attention
Dec 2, 2022 at 4:09 PM Post #2,196 of 9,916
Dec 2, 2022 at 4:24 PM Post #2,197 of 9,916
I hope it works out for you cobra, this is probably the best bang-for-buck tweak I’ve seen in my system, other stuff like tube rolls and cap rolls are great, but this is foundational and changes the incoming signal before it ever sees all those wires, plugs, transformers, etc. I’ve never seen anything other than glowing reports so far. Consensus is important, there are ways to measure that don’t require lab equipment.
Dec 2, 2022 at 4:27 PM Post #2,198 of 9,916
I was thinking about trying an "audiophile grade" fuse, but they're expensive af.. Lol. I do have the "upgraded" Gustard 3.15a fuse. Don't know that the juice is worth the squeeze here. But I'm hopeful about the fiber Ethernet!
Dec 2, 2022 at 4:31 PM Post #2,199 of 9,916
Look into Acme Labs fuses, they’re $20 and have a lot of fans. Revolution sells them.
Dec 2, 2022 at 4:40 PM Post #2,200 of 9,916
If you are referring to “Kit 5” in your link then Yup that’s perfect and similar to what I use
This is the single cable you need
Proceeded blindly, but glad it was correct..Thanks again.
Had some extra change and got me an LPS too...
Can't wait for some testing... :ksc75smile:
Dec 2, 2022 at 5:10 PM Post #2,202 of 9,916
I don't have a story, I'm just amazed by the funny claims.
Well your pm to me yesterday was somewhat different then you claim here ,….however that’s not why I’m responding to you . All of your responses on this thread it’s obvious your just a troll with a chip on your shoulder, you lash out over tiny issues , what do you care what complete strangers buy with their own money ? are you some sort of Ralph Natter of home audio ? Wait don’t answer that I won’t be reading it …
Your recent joining here is suspect after going over your responses including other topics you have little to nothing to add , your ready to pounce on anyone for comments you don’t approve of ,,.
Dec 2, 2022 at 5:12 PM Post #2,203 of 9,916
Nice!!
A headache that I didn’t mention is the DC cable barrel connectors sizes.
Mine were 5.5mm x 2.5mm.
You’ll need 2 cables @m-i-c-k-e-y. Usb to whatever size barrel connector.
These units are light and small.
I mounted them will double sided tape to the side of my media cabinet.
Dec 2, 2022 at 5:42 PM Post #2,204 of 9,916
Nice!!
Yep ordered them too. Mine has the same barrel connector as yours...
We think alike -> 3M Dual Lock
Dec 2, 2022 at 5:47 PM Post #2,205 of 9,916
Me thinks a better place for you with like minded angry old men is ASR , there you can let it all out joining in with pounding fists , grit teeth and tears .
SBAF :ksc75smile:
ooopss... might be deleted/censored
