politbureau
- Nov 9, 2010
Stuartmc mentioned a while ago that he likes to use I2S from the U12 to the X12, but he also said that he felt that the quality of the HDMI cable made a significant difference.
I personally tried I2S from the U12 to the X12 with ONE cheap HDMI cable and felt that I preferred going straight to the USB input on the X12. I'm not interested in testing more HDMI cables, though, to see if I can notice improvements.
Conquerator2 felt the same way as I did about preferring the X12's own USB input over the U12, but I'm not sure if he used I2S.
I've heard similar things. A high quality HDMI patch cable might make a difference, though I've heard very good things about the X12s internal USB card.
Rb2013 has replaced his U12 with the Melodious MX-U8 and says the sound is a big step up. Sadly the I2S connection is RJ45, so you'd need to either buy a custom cable (they are out there), or build your own.
