stinkytofus
- Dec 4, 2014
Why people say the amp is alright ? Whats different about the amp vs the amps from other brands at similar or higher price points
I'm starting to feel that I have to put forth extreme praises in each and every headfi thread I join. Please remember that each of us is enjoying the m9xx with different headphones and different purposes, and also we have different experiences with different stuffs. I don't think I'm expecting too much about the m9xx, but at the same price the idsd micro can drive practically any headphones on the planet and the ps sprout can drive speakers. They both have a solid dac section IMO.
That all said, I sold the other 2 to keep the m9xx. I just love its DAC section that much.
Of course the m9XX isn't going to be as fully-featured or powerful as a dedicated head amp. The amp it does have is a great expression of the DAC section, with some neat options in a classy, minimal interface. Unlike some other DAC/AMP combos, the line out and the headphone jack sound pretty similar (both great).
so are you recommending a dedicated amp and a separate dac? which would they be?
what other amp/dacs should i consider that is around 300-1000 range that offers better performance than m9xx?
the drop for the m9xx is ending in two days so id like to either pick one up or consider another
It works great with a pair of headphones...
Seriously though, from what I've read the DAC in the m9xx is excellent, but the amp section is mediocre - so you could get a better standalone amp and put it in between your m9xx and your HPs.
That's what I have done, and the dual HP plugs on the M9XX are still handy when she and me want to watch something on netflix etc.
Not to beat a dead horse, but how do you separate the amp from the dac? Aren't you always hearing the amp with the dac even if you play if through another amp? Like the Mojo?
Are you saying the amp is not up to driving some headphones and another amp helps it in that regard?
So aren't you using the amp to a 90 setting? Just like the Mojo? The amp is not out of the circuit but at a line level voltage? Is ths correct?
90 is "unity gain".
Please see this, from the source: http://www.head-fi.org/t/785553/grace-design-x-massdrop-m9xx-dac-amp-review-first-impressions/30#post_12020699
It seems to me, anything feeding an amp, be that dac, cd player, whathaveyou, to or bypassing a preamp, is that not in some way "double amping"?
Important point here is the quality of the output device, well described immediately above, into a -high- impedance load. And I'm confident in saying it's very high quality.
