Got my new GR06 (in india)..4 days..still burning. It doesnt sound as reviewed on headfi (joker)
Oct 13, 2012 at 3:02 PM Post #16 of 25
So..
comply nt good enough?
how do i decore a tip?
I am new to this type of mods..!
can u refer me a link for the same?
Comply is good, just that the foam tips included aren't Complys.
http://www.head-fi.org/t/478766/shure-olive-guide-strech-decore-photos
Oct 13, 2012 at 10:52 PM Post #17 of 25
I just use the tips that came with them. There's like 12 of them, one of them's gotta work, no?
I never liked the comply foams, actually I never liked any foamies, they usually take away too much of the treble.
But if you want foam tips, I think most people recommend the shure olives.
Oct 14, 2012 at 6:39 AM Post #18 of 25
are comply tips good?
i can get T100,T200,T500
which one is better?
I'm glad you're liking them better.
I think the comply's you mention are the same but different sizes so they will fit different IEM's.
Have no idea which  one will fit the GR06 though.
Oct 14, 2012 at 6:44 AM Post #19 of 25
Select a set of GR06 tips that came in the packet you'll never use (say small etc..) then cut the inner core off the tip. Then.... slide that over the nozel first. You'll then be able to use all sorts of tips that usually wouldn't of fitted. It's kind of like making an adapter.
http://www.head-fi.org/t/579151/gr07-tips-thread/105#post_8634431
Oct 14, 2012 at 9:09 AM Post #20 of 25
Do try the bi-flanges if there are included in the package.
Oct 14, 2012 at 9:20 PM Post #22 of 25
shure olives are not available.. only comply i can get my hands to.. so as H20Fidelity said..i can make an adapter.. bt tell me which comply's would fit..? i mean near to fit..
Using the adapter I mentioned T500 Comply will fit. Also these tips linked which many members use.
Also, if you only want one size check the sellers listing.
Not your country's ebay? Copy and paste the item title into your ebay.
http://www.ebay.com/itm/earbud-replacement-tips-tip-In-ear-earphone-memory-foam-SMALL-MEDIUM-LARGE-/160837891193?pt=US_Headphones&hash=item2572af7479
Oct 15, 2012 at 11:14 AM Post #24 of 25
To find the tips that fit, you can use our tip finder on our website. ComplyFoam.com - it's right there at the top.
So..
I think you'll find that the Comply tip delivers a great experience. We have a lot of support among the community here. Plus we stand behind our product and our customers. If you want a coupon code, let me know.
