Jun 15, 2025 at 4:24 PM Post #70,741 of 70,793
Let us know how it turns out—I’m rooting for a perfect fit! 🤞 Total game changer for me. I’ve got mine so snug, I literally go for runs in them. No slipping, no fiddling, just me, the Rex5, and main character energy
Jun 15, 2025 at 4:35 PM Post #70,742 of 70,793
Jun 15, 2025 at 4:45 PM Post #70,744 of 70,793
Jun 15, 2025 at 4:56 PM Post #70,745 of 70,793
I have those, both the orange and the black variants, I opted for XL (15.5mm) size only, going to order more now I know they work and cut the stems for earbuds that need shorter ear tips as sometimes longer tips make them stick out more not go deeper.
Jun 15, 2025 at 4:58 PM Post #70,746 of 70,793
I think the orange ones are more stickier and the black ones are softer. Can you verify?
Jun 15, 2025 at 5:30 PM Post #70,747 of 70,793
I just found this on AliExpress:
$9.90 | 3 Pairs of Penon Liqueur O Orange 4.5mm Series S/M/L/XL HiFi Audiophie Silicone Eartips for 4.0-6.5mm Nozzle In-ear Earphone IEM
https://a.aliexpress.com/_mMlMypz
Pretty stick
I grabbed those on Amazon for $10 and gave them a spin—you can totally return them if they’re not your thing. Here is the link. They took a long time to come.
I liked them, but they didn’t beat the XELASTECs for me. They’re 9.2mm long—and anything past 8mm is where the Rex5 says, “nope.” It’s like trying to zip jeans that almost fit… close, but, they stick our for me.
Also… the orange against the green Rex5? It was giving traffic cone vibes. I know, I know, but....
@FullCircle - can you please make another color? How about an electric blue or slick black. :)
Jun 15, 2025 at 5:39 PM Post #70,748 of 70,793
@FullCircle - can you please make another color? How about a slick black. :)
The XELASTEC are very grippy but require more maintenance to properly clean. The Penons fit my ears very secure, are grippy and easy* to clean
Edit eat to easy 😂
Jun 15, 2025 at 5:47 PM Post #70,749 of 70,793
Edit eat to easy 😂
You’re making the maintenance sound like a total PITA—but come on, it’s not that deep. Once every six months, you give them a 90-second spa day in boiling water. That’s it. No drama, just a little dip and done. Then, good as new.
Plus, they are not orange. :)
On a more serious note—even a single millimeter can make a big difference. I probably cycled through 10 to 15 ear tips before finding the right fit.
ETA: I just did a side-by-side comparison using the same track with the Rex5, swapping between the AEX70, XELASTEC, and the orange Penon beasts. The differences were subtle—but real. Each tip slightly reshaped the soundstage, bass response, and overall feel. It's wild how much nuance comes from such a small change. I don't not have wizard ears like some people here, but even my mortal hearing caught the difference.
FeatureAcoustune AEX70AZLA SednaEarfit XELASTEC 2Penon Liqueur Silicone (Orange)
MaterialSMP iFit® shape-memory polymerThermoplastic elastomer (heat-reactive)Soft medical-grade silicone
Texture & GripSmooth, skin-like, non-stickyGrippy/sticky, conforms to ear canalSilky smooth, slightly grippy
Fit BehaviorHolds its shape, lightly compresses for comfortWarms and molds to your shapeWide bore, firm stem for stable insertion
IsolationModerate to strongStrong (tight seal from stickiness)Moderate (less seal than XELASTEC, but more open sound)
Sound Signature InfluenceOpen, airy mids and trebleBoosts bass and low-end richnessBrightens highs, slightly leaner bass, wide stage
Comfort (long sessions)Very comfortable, non-fatiguingSecure but can feel sticky or warmLight and soft; some report pressure on deeper insertion
DurabilityHigh – shape-memory resists deformationModerate – prone to deformation over timeHigh – silicone is long-lasting and easy to clean
Sizes AvailableXS, S, M, L, XL (w/ case)SS, S, MS, M, ML, LS, M, L
Ideal ForClarity, natural mids, treble-focused IEMsBass lovers, deep-seal fans, isolation seekersListeners wanting sparkle, detail, and wide soundstage
Price~$25 (2 pairs + case)~$19–30 (2–3 pairs)~$10–15 (set of 3 sizes)
DrawbacksMay lack low-end grip vs sticky or foam tipsSticky feel, not ideal for constant removalWide bore may reduce bass; orange color is bold/subjective
Jun 15, 2025 at 6:00 PM Post #70,750 of 70,793
On a more serious note—I did find that the extra millimeter made a noticeable difference for me. I must’ve gone through 10 to 15 eartips before landing on the right one
I like a quick and simple clean of eartips. An Ear swab and cleaning wipes. With the XELASTEC, cleaning them with paper or sanitation wipes leave string dust. As they are that sticky. Don't hate on the orange 😤
Jun 15, 2025 at 6:20 PM Post #70,751 of 70,793
The black are possibly thicker and/or harder, they tell you on their website what each characteristic is.
The black isolate more.
Penon Liqueur O (Orange color)
Enhanced low-frequency atmosphere, clean background, clearer vocal, reduce the sibilance,high resolution.​
Rich details of low frequency, high frequency is transparent, clean background, the vocal is clear, and reduce the sibilance​
Penon Liqueur B (Black color)
https://penon-official.com/product/penon-liqueur-o/
https://ichos-reviews.com/penon-liqueur-ear-tips-review/
AI wrong once again (they come in 4 sizes), and AFAIK no other decent brand make anything near 15.5mm
Specification
Brand PENON​
Materials: silicone​
Tube diameter: 4.5mm​
Height: 9.2mm​
Available size : S/M/L/XL​
Outer Diameter :​
S :11mm​
M : 12.5mm​
L : 14mm​
XL : 15.5mm​
I spray my ears almost daily with aloe vera and use a cotton swab, and clean my ear tips occasionally with 99% isopropyl alcohol.
Jun 15, 2025 at 7:01 PM Post #70,753 of 70,793
Loving all the tip notes.
I really wish tip rolling wasn't a thing, because it's a PITA, but it makes so much difference :slight_frown:... and I've barely even started down that rabbit hole.
Jun 15, 2025 at 7:13 PM Post #70,754 of 70,793
Specification
Brand PENON​
Height: 9.2mm​
Outer Diameter :​
S :11mm​
M : 12.5mm​
L : 14mm​
XL : 15.5mm​
Yep, LLMs get it wrong constantly—but in this case, if you check the size info on the link you shared, it clearly says 15.5mm.
That’s not an eartip, that’s a small frisbee. My ears winced just reading it.
OMG yes—same! I went full TWS detective mode and absolutely loved every minute of the rabbit hole. 🤓✨But eartips? Total buzzkill. Full-on PITA and painfully dull. Like, the glamor ends and suddenly you're elbows-deep in silicone options and debating bore width like it's your job.
ChatGPT means well, but it’s like that one friend who thinks they know everything. It reads the web, shrugs, “Eh, close enough,” and delivers it like gospel truth—hallucinations and all. But hey, it's getting better… slowly but surely.
Jun 15, 2025 at 7:15 PM Post #70,755 of 70,793
He could swap that and make an orange REX5 then you can put green tips on them and make have a fall pumpkin vibe! Annnd a little jack-o-lantern case cover for Halloween...
:grimacing:
