HeadphoneAddict00
Technicz AZ80, although it's not as good as Airpods they are the closest I've tried.Have you used the Air Pods Pro 2? Looking for something with comparable ANC/ transparency mode.
Side note: If you remove the foam from AZ80 tips you get significantly more resolution, it removes the 'blur' from the sound almost completely and resembles a nozzle driver more. As long as you don't EQ up the treble it doesn't sound grainy or sharp at all. It also makes the fit better due to increased flex and reduces irritation from the foam
