turbobb
- Feb 12, 2014
...use a small strip of white silicone tape wrap (Loctite GO2 Wrap, often used for pipes) to secure the shortened green stem to the earbud speaker stem. I pulled the tip inside out to get better access to the tip stem and the speaker stem. This provides an air tight seal and a secure lock of the ear tip. When you want to remove the ear tip, the silicone wrap can be unstuck from itself. The tape leaves no residue.
Brilliant idea! I suppose the standard plumbing tape would work as well.
