Jabra Elite 85t - First Impressions!
I've just had a couple of hours with my new Jabra Elite 85t wireless IEMs and and here are some first impressions in case these are on anyone else's TWS shortlist.
Packaging
Very good, fuss-free packaging. Mostly recyclable cardboard too, if you're a 'greenie' (which I am). It's typical IEM packaging and just contains the minimum that you need.
Initial Setup
Charged the case using a USB-C cable (which is also included). I could have used wireless charging too as the case supports Qi charging. The charge status LED on the front of the case is simple to understand. They were supplied almost fully charged so charging to full charge for both the case and the earbuds took just a few minutes. Whilst I was charging them I installed the Jabra Sound+ iOS app on my iPhone 12 Mini. Once charged, I took out the earbuds and put them into my ears using the stock Medium tips which were preinstalled - you get one pair of Small and one pair of Large eartips in the box. Initial feel was they weren't quite pushed into my ear properly, but actually were!
As this was a first-time use, the voice prompts from the earbuds guided me to run the app and begin the setup. The Jabra Sound+ app is pretty decent. It's been designed quite well and is fairly intuitive to use. It takes you through the steps you need to get up and running quickly. The app updated the firmware in the 85t earbuds as part of the initial setup process. Updating the firmware did take quite a while: something like 13 minutes. You have to put the earbuds back into the case to get the firmware updated and the case LED flashes purple during the update process.
One of the tasks included in the app is the MyFit test - this tests if your earbuds are fitted properly in your ears. My right one wasn't so I adjusted it and re-ran the test. The advice the test provides is to adjust the earbud or use another sized eartip. I changed the tip to the Large size and re-ran the test and this worked. So I have Medium in the left ear and Large in the right ear - this does freak my OCD out where everything must be perfectly symmetrical!
There's also a MySound test in the app. This generates different frequencies at different volumes and you tap an area on the app if you can hear the sound. It does this both for the left and right earbuds and then analyses the results to create a profile for your ears. You can then apply this profile to music if you want to. I will do an A/B test for MySound on/off to see if it makes a difference another time.
There's a lot more in the app which I'll go through in the coming days. But, overall, getting the 85t earbuds personalised for my ears didn't take too long and the process was fairly straightforward thanks to a good app and the ergonomics of the 85t earbuds.
The Fit
With the different sized eartips, the fit is very good. I generally don't like wearing IEMs, yet here I am a few hours into wearing them at home and enjoying them. The tips are quite shallow. This is mostly good as it doesn't feel like I'm wearing earbuds. On the downside, the centre of gravity is further out from your ears so it sometimes feels like they aren't inserted properly so you may end up trying to twist and push them further in until you get used to the sensation.
As the earbuds are vented, there's far less of the feeling of ears being plugged. It's still there, just to a lesser extent. Shaking my head with some vigour doesn't dislodge the 85t earbuds, which is a positive.
Each earbud has a single push button for call and music functions, and is programmable via the Jabra Sound+ app.
Call Quality
This was an important requirement for me. I called my home phone's answering machine and made a 30-second voice test. When I listened to it on my home phone's answering machine I was a little disappointed. The call quality wasn't as good as I had hoped for. It was very 'fuzzy' and loaded with noise. Given it's the Jabra brand, this made it even more disappointing. I'll try some WhatsApp calls to test this out more.
Music Sound Quality
My music source is the Neutron Music App and the TIDAL app, all playing music in lossless CD-quality or better. I have not made any EQ adjustments in my music source app or the Jabra Sound+ app, so these impressions are for a 'flat' sound EQ.
First impressions are of a lovely, mellow sound signature. There's certainly no harshness to it, which means it's very listenable for extended listening sessions. It's a great sound signature for bedtime listening, which is a positive for me.
There is a good amount of airiness and detail in the sound. The mid-bass is slightly pronounced. It doesn't feel like I'm listening to heavily processed music through AAC. The Jabra Elite 85t manage to do a good of keeping my music sounding musical, which is extremely important to me, The is plenty of volume available - I'm listening at 50% and it's just at the point of being a little too loud in my current quiet environment. I'll need to bump up the volume when walking outdoors but there's plenty available.
My reference for music sound quality is my Beyerdynamic Xelento IEMs and those are clearly superior for music quality in terms of clarity and depth. However, for casual listening, the 85t earbuds are 'good' - if I was marking them out of 10 where the Xelentos were a 10, I'd give the 85t a 7 out of 10. When I'm walking outside there's a ton of noise around me so that equalises things a bit more, with the added convenience of not having a wire in the way.
Keep or Return?
I haven't bothered with the EQ, ANC or any of the other fancy features of the Jabra 85t earbuds yet, those are still on my To-Do list. For the price I paid, the ease of use, ergonomics and 'good enough' music sound quality, these do tick a sufficient number of boxes for me, although I don't have any other TWS earbuds to compare them directly to. The phone call quality, or lack of it, is something I need to explore over time as there may be options to improve it. Soooooooooo...
Answer: Keep!
All of the above are my personal opinions. YMMV.
[Edit] Just had my first long phone call using the 85t earbuds via Facetime Audio, and the incoming audio was crystal clear and when I asked the caller how my audio was he said it was very clear. That's a big relief to me!
