Since the black(would have preferred the blue) had the 1-day shipping I took a flyer on the Sabbat flagship...
The quick pics and I'll get the first quick impression/experience in before anyone else here
The presentation is indeed nice and they include a decent amount of tips though small bore is probably not the best I'm thinking so pretty sure some other type from the ole' kit will be the better choice. Case is solid and handsome and Qi compatible though you have to leave it open to see the LED. Should fit most normal length tips and all the shorter wireless ones. Even Sedna Earfits M work in the case. ML have to wedge in a bit but still work to start charging but the case doesn't close that last tiny bit. Most tips should be okay till really long or wide and firm.
They pair and connect as fast as you'd want. Connection seems rock solid. The ergo shape is easy to fit gives a good amount of isolation(will vary with tip) and is good to press the button and not bother the seal. Buttons are nice so you'll never have any accidental presses and you can grab them any way you want.
The sound is very nice for $99. So, far I would like to wait on the dynamic part to burn in some in case of any change. Good reach and some feel but a little bloom on it and the detail and texture is a bit smoothed over so hoping the burn in and tip choice will round them into the best shape. The 7mm magneto part, which is very planar but more electret-like on how it uses charge and can't produce much bass hence the magnetostat always being a combo with it's dynamic helper, does it's job well and has extension, clarity, and liveliness. The good extension and detail are good for TWS to offset what is lost over BT. No bad cable choices here or alloy housing so no Tape style problems with being detail freaks at the cost of the F.R. and needing some kind of fix. Not polite but not strident or sibilant. Energetic but not too aggressive on the highs. They will bring the treble to the party in a evident way. My previous Victor was darker and compared to the MTW2 in signature and my Audio-Technica is in the same way so these will be more hybrid sounding in adding the treble driver. More Falcon Pro than Falcon if you will. Still want the bass to tighten up a bit with the best seal to show more of what is underneath as far as texture and layering a bit. It will happen with run in and/or tips or will need to be done via EQ.
I think with JVC Spiral Dot SF they come together for my ears. Coherent, a big sound with a clean W signature. Male vocals pop, bass has some punch low and a nice lighter snap a bit higher, and the treble is up with good extension and shimmer and the roll on either end is minimal and pretty satisfying for a TWS. They can certainly sound excellent and dialed in right few will complain for $99 for the sound they are capable of. They have clarity, detail, extension, some room in the presentation, and take to EQ well to tweak.
The pros so far:
- Good build and shape and looks
- Good connection and stability
- Good fit
- Good volume with more headroom than many other TWS
- No accidental pressing and still button mashing is not an issue
- Good value
The cons so far:
- Buttons could be a bit bigger esp. for bigger fingers
- The W sig is not the most coherent out of the box (more tip related?)
- Narrow bore tips cut the stage height some
- TWS style short tips have no issues for sound but they only give one size
- No ambient or talk-through mode
- L/R indicators are stamped in so won't rub off but are not easy to see with no color difference(not symmetrical in shape so not a big deal)
Sabbat did a nice job with these!
