pkcpga
I went for a 5 mile jog this morning in my Falcon pro’s, no issue with seal. They do sit fairly deep in your ear almost like a custom. I did switch to comply foam tips, they seem to work much better for me. I use small comply tips and let them go into the ear all the way until the housing touches my outer ear. I’ve noticed if they don’t sit deep enough you loose some bass and details as well as move around, since they have a long inner ear part to them. They seem to rely on depth for fit and sound over a hard seal. If you haven’t worn custom IEMs before they definitely will take some getting used to. I start with the longer part a little more horizontal and turn them a little counter clock wise when going in.I think there are two different models.
care to share your for secrets. Mine are only good for stationary listening. Move an inch and the seal breaks. How far in are you pushing them?
On the topic of isines, I’ve owned the 10, 20 and i3, and the 10 is the best value of the bunch by a mile.
