Shadowclash10
I think you mean up to 6 hours?My hope is the SQ gets closer to the N400 ... battery is rated at 8 hours.
Thanks for the tip. White cancelled. Black ordered. They look strange enough - I think low key is better in this circumstance.
Looks like up to 8 hours. Enabling ANC and Bixby lower the estimated time.I think you mean up to 6 hours?
Any other technical support? Codecs for example?Ruh Roh - only IPX2. That may be a deal breaker. Hmm.
Uses Samsung's scaleable codec for sure. Not sure about others. Edit - looks like AAC as well.Any other technical support? Codecs for example?
Probably AAC as well. Since they specifically say that apple users can use their app.
I wonder if they crippled SBC again. It'd be nice if they had APT-X, highly doubtful.
Well, as I understand it, they are almost always lithium ion, so the same rules apply that you would use for your phone. I've stopped topping them off to 100%, I try to keep them <90%, closer to 80%. It also helps if your battery doesn't fully drain. The only times I would charge my stuff up to 100% and let it deplete all the way is if I am using them for a long run, say, an international flight or smth. This does mean that I go for TWS with longer-than-average battery life. Quick charging stresses the battery out, but, sadly, generally (not sure if there are any that give you the option) TWS that have some form of quick charging don;t give you the option to turn it off. Oftentimes, that quick charging feature is very useful, but I don't need them to charge to full in 40 mins when I am going to bed, do I? But, yes, just follow the same guidelines that you would use for your phone.Anyway friends just to ask, for your TWS/BT dongles and maybe even DAPs/amps, do you only charge them when the battery is almost depleted? Or do you top up charging "sips" at regular intervals even with just slight battery usage?
Which would preserve battery lifespan in the long run? TIA!!
Argh. I hate it when buds need you to go tip-rolling . How big roughly is the charging case? Always wary of circular ones, cause they can bulge alot. Roughly how much battery life are you getting out of them?Wow. So easy to get out of touch with all this! I had a baby back in early April and with the terrible new post notification system, I completely forgot about this! Had ~300 pages to catch up on the last few days.
I got my Tranya T10s a couple of days ago. So far I have a love/hate relationship with them. They definitely have potential, but they seem to be VERY picky about tips. So far I've had the best luck with the Misodoko Pro foam tips, some random ones I found in my collection that are probably from another TWS set but I can't remember which one, and oddly enough the Galaxy Buds+ tips sound great on them too. Those tips don't even sound that great on the GBuds+! With the right tips, the sound is amazing! Mids and highs aren't as defined as the B530 or B530+, but almost there. The bass has the potential to be monstrous. I had to dial it back a bit in the EQ to not overpower everything else. The only thing I'm not happy with thus far is that without the right tips and more EQing than any of my other Tranyas, they get distorted in the upper mids and lower highs. Like electric guitars take on an almost scratchy quality that is uncomfortable and male vocals can get distorted.
Comfort-wise, they're right up there with the other Tranya products I love. Not quite as form fitting as the B530s, but pretty darn close. They don't look like they would be as big as they are.
I think I still prefer my B530s, but I'm going to give these some workouts to see if they can get the kinks out. If the audio quality can match the B530s after some burn-in, then a B530 with USB-C and Qi charging is a no-brainer!
Agreed. Doubt they will have aptX. Clearly pushing their scalable codec.Probably AAC as well. Since they specifically say that apple users can use their app.
Mmm, well, there is the RHA CL2, but those aren't true wireless, those are in the neckband style. I searched the thread for "planar", but nothing came up... Sorry, I don't remember hearing anything like that.A couple of months ago, someone posted a link to a small audio company developing a planar TWS. I can't find the post. If anyone can point me to it, I would appreciate it. I was going to follow up on the progress.
Didn't feel like waiting. 3 mics and open style look like what I have been waiting for since I want them primarily for calls.Thanks for the tip. White cancelled. Black ordered. They look strange enough - I think low key is better in this circumstance.
Thanks me too. It was a small audio company - I emailed them about it awhile back and they said August release. Now I can't find the email. It was a really interesting item.Mmm, well, there is the RHA CL2, but those aren't true wireless, those are in the neckband style. I searched the thread for "planar", but nothing came up... Sorry, I don't remember hearing anything like that.
Found it. Bumping the thread. Edit - :Seems Obravo is coming up with a planar TWS!"Dont know much about this company but its nice to see some innovation. Anyone familiar with they stuff? Any details on these?
