Apr 18, 2020 at 6:24 AM Post #21,391 of 70,826
I use an app called volume butler for this reason. I click on a home screen widget and it puts my phone into do not disturb mode and alters the whatever volume you want. Then when I'm done I click the other one. For my wired headphones I have automate and a mini program that put its into silent mode when headphone jack inserted. Then toggles my profile back on automate when it is pulled out.
I use a similar DND feature, just wondering if there’d be any space saving / less clutter if a bud is music play only.
Apr 18, 2020 at 7:15 AM Post #21,393 of 70,826
On Android if your phone had AAC you can switch it in the developer's options. Go out of the menu and go back in the menu. If it changed back to SBC from AAC then the earbud can't do AAC.
Alternatively you can check with just about any dap. My shanling tells me what codec is being used at all times one the upper right corner.
Apr 18, 2020 at 7:17 AM Post #21,394 of 70,826
Will android automatically select the best codec available or do you have to manually change it to the one you want?
Apr 18, 2020 at 7:21 AM Post #21,395 of 70,826
Quick question, is there a technical way to check if a TWS can do AAC without having to rely on seller’s claims? Want to check which of my buds are SBC only ...
In my experience it will grab the best codec, from LDAC, APTx HD, APTx, AAC, SBC in that order, but I have heard of some phones doing weird things like picking AAC over APTx and what not.
Apr 18, 2020 at 7:58 AM Post #21,396 of 70,826
My fiil t1x always default to AAC on android, all my other AptX able tws always default to AptX on android.
Apr 18, 2020 at 11:28 AM Post #21,398 of 70,826
That's because they don't support aptx. (That's why I gave them away as a gift)
Yeah the t1x doesn't support AptX, but their aac can put some AptX able tws to shame.
Apr 18, 2020 at 11:47 AM Post #21,399 of 70,826
Not that my word means anything but I really loved the sound of the Tevis. I had no idea you could get that kind of sound with truly wireless earphones at that price point.
I only wish they were more secure in the ear, I had to return them because they'd definitely fall out of my ears when I was training.
I'm finding it really tough to pick a pair now, I'm really close to buying the Jaybird Vistas because they're so suited to fitness training but they've only got SBC codec. Think I need me some aptX!
[/QUOTEDang the vista's only have SBC!? That surprises me. I haven't tried them but have you looked at the Liberty air 2 from anker? wonder if they would fit what you need.
Apr 18, 2020 at 2:10 PM Post #21,400 of 70,826
Oooohhh, that I have to try! Which Shanling you have?
Apr 18, 2020 at 2:18 PM Post #21,401 of 70,826
I guess my M3s only shows me this ‘A’, this might be why I never realized it could be the codec
Apr 18, 2020 at 3:10 PM Post #21,402 of 70,826
I haven't looked at them, no. Thanks for the tip I'll check them out.
Really annoying that it's only SBC on the Vistas (in a first world problem kind of way!). The specs look pretty spot on for my needs except that one point!
Apr 18, 2020 at 4:06 PM Post #21,403 of 70,826
Generally, yes, but it depends on the phone. My Galaxy S9 picks LDAC or aptX when paired with a compatible device. However, I have an old LG Aristo phone on an extra line which seems to prefer AAC over aptX (it's on Android 8 if that matters) but will default to aptX when I connect my ES100, which has AAC disabled.
Apr 18, 2020 at 5:08 PM Post #21,404 of 70,826
Has any of you tested the difference between the MTW2 and the B&O E8 3rd gen?
