Got the Pulse infinity today.
Hooked it up with Jay's audio LPS with 2G cable,
data end to computer and power end to an Anker USB portable battery charger to emulate plugged in usb power.
(the charger it self seem to shuts down after the initial hand shake, due to having no active load. )
, set everything up on windows, play via JRiver through ASIO, DSD bit perfect output, etc. , after a bit fiddling with settings, everything was good to go.
The initial impression? Not bad, not bad at all.
The DAC managed to squeeze some subtle detail out of some sound tracks compare to Buffalo II without feeling too harsh or distracted.
The instrument separation is slightly better as well.
The over all tone is pretty much on par between the Buffalo II and Pulse Infinity though.
The only gripe is that the lower drum/base doesn't seem to pack as much punch as the Buffalo, hopefully this will be fixed after few hundred hours of burn in.
Also... I am running balanced HD800, low gain.. at -24 dB for a normal listening session... this seem to be quiet a bit of attenuation for low gain settings... anyone else is having similar experience?
