Geek Pulse: Geek desktop DAC/AMP by Light Harmonics
Mar 20, 2015 at 6:13 PM Post #6,541 of 13,808
Jexby, a 2g split cable was definitely given for backing the THD perk.
(I saw it on the previous survey system before the new one hit).
  @chartwell85
Casey are we supposed to be trying to add the "1G free cable" that came with a stretch goal being met,
as items on our Survey?
or are those cables (and other stretch goals) automatically remember/tracked with the LH order details?
I don't recall a 2g-split cable from a THD Pulse perk, but could easily be mistaken.  (despite backing the THD
thanks!
Mar 20, 2015 at 7:45 PM Post #6,542 of 13,808
I have navigated the survey and confirmed all of my perks from the 18 months I have participated. A bit convoluted, but it seems to have worked as intended.
Mar 20, 2015 at 9:52 PM Post #6,543 of 13,808
  Can anybody remind me which free cables are supposed to be received with a Pulse Infinity ?
I remember the LightSpeed 2G-split from the THD perk (was it 1 meter?), but was there also a LightSpeed 1G included with some earlier perks? Or was it a Slacker (it seems Slacker is not selectable in the add-ons list).
I must admit that the survey is very confusing, considering that description of old perks is not available anymore in the IGG site
Only those who backed the THD+/Infinity perks by a certain date will be getting the 2G split cable free. I am unsure as to what that date was though.
Mar 21, 2015 at 12:59 AM Post #6,544 of 13,808
Eh... does anyone remember the pricing of the THD + Naked resistor upgrade?
and each of them individually?
Checking my perks right now... but because I did the upgrade in two parts... I am not sure if they factor in my pricing together or not.
Mar 21, 2015 at 1:09 AM Post #6,546 of 13,808
  THD $168. Naked resistors $129.
Thanks bud.
Welp... looks like they left out my later contribution on my upgrade then.
nvm.. figured out how to stated what product i am expecting.
Mar 21, 2015 at 1:14 AM Post #6,547 of 13,808
Indeed true!
Found this in my Evernote
"Free 2G USB cable for early Xfi and THD perk, on Dec 27 2014"
Mar 21, 2015 at 1:19 AM Post #6,548 of 13,808
Jexby.
   So did you ended up adding the 2G split cable into your backing log?
I am debating whether I should do it or not as welll....
Indeed true!
Mar 22, 2015 at 2:26 AM Post #6,551 of 13,808
To all on this thread:
I got the Xfi and the accompanying Lightspeed 1G cable this morning (live in India). With this, the four items that I funded for (also got the Geek Out and the T shirt much earlier) have been delivered. I should be putting the Xfi through its paces in the coming days.
A big thanks to all of the LH team members.
Cheers
Koth
Mar 22, 2015 at 2:50 AM Post #6,552 of 13,808
Wow!....surely somebody is really excited. There goes your Sunday!
Mar 22, 2015 at 4:29 AM Post #6,553 of 13,808
M-i-c-k-e-y;
thanks. Its been an hour plus now. Quick reactions: the balanced out gives better SQ than the SE (remember all my opinions only)... Was using the HD 800 SE...the volume level was at -14dB to hear the detail I normally want to hear...switched to the LCD-X balanced..wow, turned the volume dial down to -31 dB in quick time....using the FTM digital filter...to me sounds the best of the lot.
Mar 22, 2015 at 4:58 AM Post #6,554 of 13,808
Fellas:
I messed up with the gain selection when listening with the HD 800. Use the high gain selector with high impedance cans (as mentioned clearly in the manual). I was listening on medium gain
. Anyway, it sounds much better now. Again early impressions, but the Xfi seems to like planars better running balanced.
