- Feb 23, 2011
"Floating ground isn't new stuff and I don't think it has anything to do with the USB 2.0 specifications."
You're 100% wrong, and you can only think as you do because you haven't actually read the standard.
Go to usb.org, http://www.usb/developers/docs/usb20_docs/
download the 2.0 Zipfile
Read page 141-142
Also read page 148, document name usb_20. pdf figure 7-1
This clearly shows a High Speed USB Tranceiver (transmit/receive circuit; clearly shown is that items must be referenced to ground)
These resistors are in downstream (DAC for audio devices) and the ground is system ground (read PC ground)
Also, from page 142 (pdf page) "6.8 USB Grounding: The shield must be terminated to the connector plug for complete assemblies. The shield and chassis are bonded together. The user selected grounding scheme for USB devices, and cables MUST (my emphasis) be consistent with industry practices and regulatory agency standards for SAFETY (my emphasis again) and EMI/ESD/RFI."
In other words, there is an implicit requirement to 'do as everyone else'......which is why it is a STANDARD.
Now honestly, it really is black and white, grounded or ungrounded, right and wrong, there is no ambiguity whatsoever. The LH device does NOT follow the accepted standard, and this is the only reason there are any incompatibility issues.
Supporters of LH should be directing their comments to LH about this, rather than dismissing legitimate concerns about both the product itself, and the way other manufacturers are actually being blamed for making components which are following an accepted industry standard.
1) that link doesn't work
2) whatever PDF you have, it's not the same as mine so the pages and references are all screwed up
3) "This clearly shows a High Speed USB Tranceiver (transmit/receive circuit; clearly shown is that items must be referenced to ground)
These resistors are in downstream (DAC for audio devices) and the ground is system ground (read PC ground)"
I thought these were transmitter/receiver USB ports, what if the Geek LPS does that? Only the output is a floating ground, not the input.
