superachromat
- Aug 14, 2013
I think you'll find voltage is more important than current with an transducer at 300 ohms. It should have more than enough voltage swing to drive the HD-800's, however I'm sure it won't beat a GSX II for instance ... but noone should expect that at the price. Whether it is "good enough" is unknown. Whether it will drive them properly ... without knowing for sure (as noone has tried the combination, obviously) ... I'd say "yes" - most likely ... and if not, it is $250 at the moment - sell it and move on ...
Ar yes. You are right. At the end of the day, its around $250 and can be sold in the 2nd hand market easily. Maybe I shall move on for the pledge too.
